Hi all
An someone explain the benefit of buying a TTP map over using one of the free Tune ECU maps.
Lanark
Lanark
I agree, 100%. My T100runs perfectly with TTP3.However, after all the mods and the TTP Tune I am one happy camper, such a difference in throttle response, low end revs and power! I would highly recommend it, as many others on here have (thanks to all for the education and info) it's put a smile on my face![]()
Once you try some of the freebee tunes out there and finally "shell out" for a TTP tune, you'll kick yourself for not doing it sooner.Many thanks...couldn't be more excited. As for this thread, I may end up shelling out for the designer TTP tunes, but would like to play around just a bit beforehand.
I don't understand that, surely all the value of a tune is intrinsic, for sure you don't buy it to look good. However just because it is not something you can get hold of doesn't mean it is worth less than something solid like a pipe or an air filter.there does not have to be any correlation between the monetary and intrinsic value.
That's exactly what I said, you just paraphrased my words and then passed them off as your own with no regard for my IP.Many software companies, even the biggest ones on the planet, "borrow" ideas and code as a starting point. By adding their own IP (Intellectual Property), they produce their own product.
LOL, how does someone so business literate have no concept of physics?Yes, software is a product as real as any piece of metal you can pick up.
Wow, I'm sure the tune was only 80 something when I did mine a few months ago.TTP3 tune ÂŁ108
Everyone I know who has gone for the TTP map has come away completely gruntled.TTP is the greatest, not one disgruntled customer and a bargain at $125 - $150 US?
TuneECU has an easy-to-operate throttle body balancing function. Takes just minutes to carry out. Much easier than messing about with vacuum gauges.With tuneecu, is there a way to balance the throttle bodies, or old fashioned vacuum gauges good enough?
