Downloadable EFI maps from Triumph Twin Power - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-12-2011, 01:54 PM   #1 (permalink)
Legend
Forchetto's Avatar
Once again here I am, blatantly contravening one the forum's posting rules and I quote: "Write concisely and do not ramble". Shame that, rambling is what I do best . Apologies to all concerned.
My rambling prowess has reached such a fine pitch that this write-up occupies two posts, as the forum limits the amount of words you can fit into one post...
Although the point of this post is to recommend a new service that I've found useful and solves many problems, I feel that for newbies benefit I ought to start at the beginning and fill-in a bit of background.
It's now just over 16 months (June 2010) since TuneECU, the "lite" version, was tried out on the EFI Bonnies. This is the thread detailing that momentous event:
http://www.triumphrat.net/ecm-and-fi...nnevilles.html
At D'Ecosse's request and with his expert guidance I tested it on my own bike. At that time we could only do diagnostics, read fault codes and reset the MIL light, balancing and testing. No re-mapping yet.
Just over 3 months later (September 2010) the full version, complete with map reading, loading and editing was deemed ready to be used on the Twins. I was, once again, asked to do the trials but I chickened out...someone braver than me was found. Don't know his name but I, for one, am grateful not just for the adventurous chap that tested it, but to its originators Alain Fontaine and Tom Hamburg. This software is a God-send for those of us addicted to fiddling with engines and had, until now, been denied that pleasure by our inability to delve into the complexities of fuel-injected bike's ECU's.
This is the thread where the full-featured version of the software was revealed to us by D'Ecosse:
http://www.triumphrat.net/ecm-and-fi...efi-twins.html
In the link shown below, there's a very useful thread, a full description/tutorial with pics is available for beginners to learn what's needed to make it work. Essential reading for beginners, specially when used together with the manual downloadable from the programs site:
http://www.triumphrat.net/ecm-and-fi...8-tuneecu.html
And, of course here's the official web address containing the program, user manuals and huge collection of standard and alternative tunes. This is being updated all the time with maps sent in by users. All very noble and altruistic. There is, however, a facility for donations to help this very useful work along, and if you're happy with the program and can afford it, I would advise to send something, if only to pay for the maintenance of the site, and the URL, and some beer...:
http://tuneecu.com/
Until this software was available some of us tried all manner of tricks, fiddles, bodges and workarounds by modifying the analogue signals from the various sensors using external components to tune our bikes for mods that could not be taken care off by the scarce availability of official Triumph maps, these being limited to the standard map, one for TOR silencers and a couple of Arrow exhaust map variants. I experimented with TPS settings, modified O2 sensor signals, interfered with temperature sensors, etc and did reach some good compromises but was never really happy, thinking it was all wrong somehow.
The reason for this was that none of those Factory maps could compensate for mods to things like the airbox. We've had several examples where removal of airbox and the fitting of pod filters yielded nothing in the way of additional power. The existing factory maps just couldn't cope with it. The main reason is that our speed-density EFI systems, unlike cars and more sophisticated bike set-ups of the MAF (Mass Air Flow) type, have pre-calculated airflow figures in look-up tables. These are determined at the development stage and remain fixed. The system has a very limited capability for self-adjustment apart from adapting to barometric pressures, altitudes, etc.
The factory has modified these airflow tables in their OEM maps to account for additional airflow with official accessory exhausts like Arrows and TORS, but do not contemplate (and certainly don't approve) of airbox removal or mods to it.
This thread is just one example where the full benefit of airbox removal was not realised, worth reading through the whole thread for some expert opinions:
http://www.triumphrat.net/twins-tech...-dyno-run.html
Some of us became very excited at the thought of being able to fiddle with all those numbers shown on the map tables, myself included. Once I found out how easy it was to load modified tunes and fiddle the figures on the tables, I removed all my workarounds and did a few changes. These were disastrous, the bike ran like crap and used more fuel than Concorde...of course this was well before I read Wayne's (Power-Tripp) post discouraging unskilled fiddling with the settings:
http://www.triumphrat.net/ecm-and-fi...e-you-can.html
Don't go away yet, continued on next post...
Old 10-12-2011, 01:55 PM   #2 (permalink)
Legend
Forchetto's Avatar
I then tried some ready-made maps, some available on TuneECU's site, some donated privately from other members and ex-members. The last one of these went quite well apart from excessive richness in some areas. This was noticeable from the sooty exhaust, dark spark plug insulators, difficulty in starting from hot and, of course, heavy-ish fuel consumption. Most other maps were fine at large throttle openings but hopeless at small throttle openings, very hesitant at low revs and prone to backfiring when shutting off and re-applying the throttle from high revs.
I put this down to the sort of cheap and cheerful dyno testing that emphasizes wide open throttle performance and impressive power figures and not enough attention is paid to driveability at smaller throttle openings. It can be done, but remapping on a dyno to optimise engine performance and driveability throughout the rev and throttle opening range is time consuming and therefore very expensive.
One of the difficulties of adapting someone else's map to your bike is that every bike is different, I don't mean small variations in production, as most maps will accomodate those, but the type and extent of the different mods, make of exhaust, baffles in or out, airbox restrictor in or out, type of airfilter, how well maintained the bike is, state of wear, etc, etc. The maps donated to the TuneECU site often don't list the full extent of the mods taken into account to create that map.
Another, I think, important factor is that we all have different standards as to what constitutes a fine running bike. One man's meat is another man's poison and all that...You can often see this on Youtube videos. The proud owner starts his bike to give you a demo of his tuning skills and you can hear it cranking for ages, rattling, misfiring, poor throttle response, "idling" at 3000 revs and generally running crap, but it's somehow aceptable to him. He's a proud and happy man...
Have you ever gone into a mate's house and noticed, for example, that his TV picture is rubbish? or his HI-FI produces lots of distortion?. When you point it out to him he often replies: "What do you mean? what's wrong with it?, sounds, looks Ok to me...".
It follows that the only way of obtaining something close to perfection is a dyno session with someone that knows what they're doing and can devote sufficient time to do a thorough job. This is not possible for me. There's no bike dyno facility anywhere near me. Spaniards, while mostly enthusiastic and skillful riders, are not keen on getting into any sort of activity that gets their hands dirty, like DIY mechanics or home tuning.
The only viable option left was to pull my ECM out, stick it in a box, and send it to Mike (Pieman) at Triumph Twin Power in the UK for him to work his magic on it, the same way he has been doing it for years for the CDI igniters on the carbed models. His vast experience in dyno tuning these bikes means that he has a comprehensive library of suitable tunes covering all manner of mods and that can be further refined to customers requirements.
I nearly completed filling in the online questionaire a couple of times, ready for sending my unit to him but always held back. These ECM's are so expensive that if it was lost or damaged in transit I would burst into tears. Even if insured your bike could be off the road for ages while they paid up. Note that this is just my personal paranoia, the chances are that your well-packaged and labelled ECM will be OK so don't hesitate in using that service on account of me. Many have done so without a hitch.
Here's a link to that remapping service:
http://www.triumphtwinpower.com/triu...e-download.php
I then made some tacit enquiries to find out if he would be interested in starting a new service whereby he would send by email a suitable tune map in TuneECU format for loading by those of us able to use the software in a reasonably competent manner at home and, surprisingly, he was already considering introducing such a service. There was a few details to Iron out before the service was available on his site. These are now sorted and the service is up and running.
See this new service here:
http://www.triumphtwinpower.com/triu...-efi-tunes.php
Note that his website is a cut above most other after-market peddlars sites with its wealth of Triumph model history, specs, technical data, advice, links and clear explanations. You can tell this has been written by a knowledgeable enthusiast and not just a salesman. Well worth reading through, no BS or outrageous claims there .
Also note that all his maps disable the O2 sensors and the maps are adjusted accordingly to obtain maximum advantage of doing so. He explains why on the site, and he can also supply the required kit which includes bungs, crush washers, copper grease, and even the material for sealing the vacated O2 sensor plugs, for a reasonable price.
There's the argument that there's no way an off-the-shelf map can work well. The only thing I have to say about that is that millions of cars and bikes are running around happily with an off-the-shelf map as provided as OEM by the makers. You don't think they adjust the map settings individually, do you?.
I am certainly happy with mine (tune 20187ttp3fi with stage 1 ignition advance). As one of the earliest users of the service I'm delighted with the results. No low speed throttle snatch, perfect starting and watch-like idling in all circumstances, no hesitation or stumbling when pulling away from low revs, seamless acceleration with no flat spots, tons of mid-range, imperceptible change-over from "F" to "L" maps and spectacular top-gear and high rev performance, no popping back on deceleration either, together with perfect tractability from as low as 1800 rpm in top gear.
If I was any happier with the way my bike runs now I'd burst...It can change from a smooth, docile, refined and tractable gentleman's express to a snarling beast with just a twist of the throttle, the option of stage 1 ignition timing advance is certainly felt at high throttle openings. I wish I'd done this a lot earlier, it would have saved me a lot of trouble.
I've tried two of his maps. The first one gave me an extra 30 km per tankfull straightaway, at first I thought the low fuel warning light had broken!, and it ran crisp and clean apart from a slight feeling of "holding-back" at certain small throttle openings (<10%). This wasn't a defect with the map, simply that Mike, by default, tries to optimise things for good power at large throttle openings together with a decent fuel consumption in cruising conditions. Most people wouldn't notice this, but I tend to do a lot of trundling along our twisty country lanes a lot with the throttle nearly closed and in a high gear.
I wrote to him explaining that I was prepared to sacrifice some mileage in exchange for perfect driveability at all revs and got a revised, slightly richer map by return of post...that's service, although I don't know if he's prepared to contemplate doing this for other people. The result, in my case, is a virtually perfect custom map, made just for me, at a fraction of the cost and bother of a dyno session and without moving your bike out of the garage. Took around 10 minutes to do the whole thing plus another 10 to reset the TPS.
The funny thing is that all this refinement and performance has been achieved while nearly maintaining the normal, factory-fresh fuel consumption. I'm averaging 54 UK mpg (45 US MPG), even with a 17 tooth gearbox sprocket which lowers the gearing and supposedly hurts fuel economy.
All the above gushing praise might lead some cynics among you to conclude that I have some financial interest in TTP, but I can assure you that I'm doing this simply as a satisfied customer. (Is that cheque in the post yet Mike?).
Of all my old workarounds I'm keeping my IAT (Intake air temperature) sensor relocation mod in place, I suspect Mike doesn't approve so I haven't told him...
This only affects things after a few miles when the airbox gets heated up and the EFI system senses this and weakens the mix and retards the timing slightly. This mod prevents this from happening and keeps up the performance and fine running over the duration of a longer trip, specially in the Summer. In the winter months the extra richness this mod provides ensures fine running in the coldest weather, but the fuel consumption goes down the toilet. Mind you it only takes minutes to replace the IAT sensor back in its OEM location if it bothers you. This mod is described on this thread:
http://www.triumphrat.net/twins-tech...mperature.html
Old 10-13-2011, 07:20 AM   #3 (permalink)
Main Motorcycle: Triumph Thruxton EFi
Other Motorcycle: Yamaha R1, Honda CB1000R
This is a very good idea and great to see, it's high time someone offered an EFi 're-jet' for 'standard' tuning stages. The only thing stopping me doing it right now is I don't want to spend out thick end of 60 quid while my modifications are not complete and I'm not sure which way to go on the inlet side. I could simply de-baffle and de-snorkle the airbox and fit a better air filter (as supplied by TTP) or I could remove the AB altogther and and fit pods BUT if I go that route I'd also like to get the TBs bored too. BUT then I wonder is it worth doing that if the head is standard. I guess the question is which is the tighter cork, the head or the TBs? I'd like to see figures for each modification 'stage' available from the 'menu'. I just can't make my mind up right now.
GDCobra is offline   Reply With Quote
Old 10-14-2011, 12:45 AM   #4 (permalink)
Junipero's Avatar
Other Motorcycle: 2011 BMW R1200RT
Thanks again Forchetto for a great post it's nice to have this all in one place. If never gotten around to replacing my stock pipes and I haven't even removed the AI yet! I know, pretty lame. But this has inspired me to finally bite the bullet. Again, thanks mucho!
"The views expressed here are my own and do not represent my employer's position or opinion."
Junipero is offline   Reply With Quote
Old 10-14-2011, 08:32 AM   #5 (permalink)
Main Motorcycle: T140J (Long gone)
Other Motorcycle: 2010 T100
Well done and about time! With such a short riding season, I could not part with my ECU until late November and would have to wait until April to truly test it. Just pulled the trigger on the 20187ttp11fi map and O2 Sensor removal kit and hopefully will get a few weeks enjoyment out of it before winter storage.
Process was quite painless and the map was immediately ready for download after the credit card transaction completed.
Will download the map into the ECU today however, the forecast for next five days is rain. I'll report back to share my thoughts after the O2 removal kit is installed and I've burned through a few tankfuls.
Stay tuned.
cheers,
j
__________________________
2010 T100 Phantom Black, Lotsa OEM Chrome, Predators, ARK, AI Gone, Fork Gaitors, Steering Damper.
2010_T100 is offline   Reply With Quote
Old 10-19-2011, 02:48 PM   #6 (permalink)
Main Motorcycle: 2004 Bonnie Black Special
PieMan's Avatar
WOW, Forchetto, that's a lengthy review of your EFI fuelling experiences, but entertaining as usual. It's great to hear your bike is running well.
.........and your cheque is in the post.
Mike (UK)
PieMan is offline   Reply With Quote
Old 10-19-2011, 03:37 PM   #7 (permalink)
Legend
Forchetto's Avatar
When I'm pleased with something I like to say so, and I'm ecstatic with my new tune.
By the way can you make the cheque in Sterling rather than this bum-wad monopoly money we use in the Continent?...
Old 10-19-2011, 04:32 PM   #8 (permalink)
Main Motorcycle: Bonneville T100 EFI
Now steady there Forchetto, at least in the REAL Europe we've still got a few bob left !!!!!
Bonny - '10 Bonneville T100 with saucy Dominator pipes, de-snorkel'd, de-AI'd, UNI air filter; De-OČ sensors.
2004 Jaguar S-type V8 4.2
thebiglad is offline   Reply With Quote
Old 10-29-2011, 12:14 PM   #9 (permalink)
Main Motorcycle: my bonnie efi t100
BIKERPIPER's Avatar
Other Motorcycle: bonnie t100
this is a fantastic thread man,
fair do's,im like a kid in a sweet shop,which one to choose?!!!
bikerpiper irish by birth cork by the grace of god
BIKERPIPER is offline   Reply With Quote
Old 10-29-2011, 12:29 PM   #10 (permalink)
Main Motorcycle: Triumph Bonneville T100
Gareful's Avatar
Extra Motorcycle: Looking at a Tiger 800 XC
Thank you
Thank you Forchetto,
Being one of the newbies I just wanted to let you know. You have helped me so many times before by answering questions I didn't know to ask yet. Tuning or remaping is something I want to know how to do and am planing on doing in the future. This post is one I needed to help me get started.
Thanks again,
Garoid
It's better to be careful 100 times than to get killed once. "Mark Twain"
Gareful is offline   Reply With Quote
What is the power delivery difference between a Vertical Twin and V Twin worldspeaker Twins Talk 60 04-26-2013 12:48 AM
Triumph Twin Power EFI Performance Tunes ThruxCM Twins Technical Talk 5 11-03-2011 08:42 PM
Triumph Twin Power (UK) No Reply jotadude Twins Technical Talk 7 08-18-2011 09:07 PM
Triumph Twin Power Up 'n' Over Caliper nickjtc Twins Technical Talk 8 07-14-2011 09:26 PM
Help with Power Commander Maps Bluetahoe Speed Triple Forum 4 05-29-2007 09:39 PM
