441 - 460 of 518 Posts
After that i think i wil continue with my 1100 atas dct
There is nothing wrong with the 900 platform as is. The frame is very stout. I've beaten the hell out of mine off road for nearly 3 years now. Dropped many times. No issues.
The problem is with aftermarket companies bolting "protection" bars to places not designed for added rigidity.
The 900 is an awesome machine and I'd buy another in a heartbeat.
My bike's in a workshop putting on some upgrades. However these are photos of my mate whose Tiger has Givi bars installed. Givi have 2 models for the Tiger 900s: TN6415 for GTs and TN6418 for Rallies, be sure to pick the correct model for your Tiger. The only difference is where the right bar attached to at the rear bottom mount.
I don't really like T-Rex bars, however their skid plate's great! It's the only skid plate mounted to the frame instead of relying on M6 & M8 holes on the engine oil sump. Some folks on Tiger 900 FB pages have done hard offroading with them for nearly 2 years and they hold up great. I'm waiting for them to arrive, I think some modifications will be needed as the T-Rex skid plate and Givi crash bars share some mounting points, hopefully it's not gonna be too cumbersome.
Some more photos taken at a Givi Point near my place:
I did not know that rally was another bar. In brazil the rally version cost double. I am giving up of buying tiger and keepin my hot atas
Are you going to do any off roading? If not, it's my opinion that tank protection bars are worthless and just added weight. If you go down on the street, there's going to be more damage than just the tank.
Given all the issues with tank protection bars across the brands, they seem to be more of a liability for off-roading on the Tiger 900s. Not a chance I'm putting them back on my bike.
What about lower oem engine bar? It seems to be a liability as well
What crash bars do you use? I dropped my friend's tiger very slowly and he charged me for scratches in the tank and fairings, handguard and mirror got scratched as well. I dropped atas and gs 850 a lot and never had any issues.
The lower engine protection bars work nicely in low speed drops, but the tank upper bars are very unstable. They are attached to the frame that supports the headlamp from the headstock. Small drops result in rotating this support. Only solution is to drop down the bike on the other side too... Best solution so far are the Barkbusters. The original hand guards snap at the first drop, so you want them. They catch a lot of momentum the upper bars won't.
Gs and atas handguards scratches but does not snap
I'll try SW-mitch next, it's bolted to the frame. Anyone have input on theirs?
i have sw motech upper crash bars on my 900 gt. The other day I threw my leg over the bike, & in a rookie move ( for a 74 y/o ) caught my jeans cuff in the r/h pillion peg. I must have pulled the bike upright at the same time, so momentum was started!
I resigned myself that I was going over, so held the bars straight & waited for the impact, which was very hard on these old ribs! However the bars took the fall, didn't bend, just very slight mark from loose gravel over tar.
Not a mark on the bike.
I will mention one thing about the Sw Moteck bars, these t plane crank bikes have a noticeable vibe at 4100 r.p.m.
its not a problem as it goes as quickly as it comes, & not there at speed limit or cruising speeds,
The SW Moteck bars have a joining rod between them at their lower level,
I noticed the vibration was worse after fitting the bars.
Putting my hand (hard) on the bars reduced the vibe.
I ordered 2x 27mm clamps & made an extra bar across the top front of the bars .
Problem solved!
I have had probably 50 bikes in my 60 years of riding, & as much as I love my Road King & my VtR Honda track bike , this Triumph is my most fun, love it
Well that was a fun afternoon...just read the entire thread on the day my UK OM dealer informed me he had a set of crash bars for me. Needless to say I declined. THANK YOU, to all for this forum and in particular this thread...unfortunately I am still unsure as to my 2nd go to which was the Sw's...more research I think....
My take on it at the moment is that for bars that are a bit 'upper' the Puig from Spain look to be the best compromise. Not too high up the bike, cross brace, and do not use the upper engine mounting point. That said, they may or may not be subject to some of the other weaknesses, but of all the bars I've looked at, I think these are the best compromise. Just a guess!
My take on it at the moment is that for bars that are a bit 'upper' the Puig from Spain look to be the best compromise. Not too high up the bike, cross brace, and do not use theupper engine mounting point. That said, they may or may not be subject to some of the other weaknesses, but of all the bars I've looked at, I think these are the best compromise. Just a guess!
Do you have these bars DamonYVR? Can't seem to find a lot of info on them, they're website is a bit sparse on info and pictures! But they do look interesting.
@Jekyll69
I have them, but here are some good pics of the Puig bars on a 900 Rally. These are over the Outback Motorteck lower bars, and the OEM skid plate. The Puig will fit over the OM or OEM lowers, I'm sure. The Puig tabs on the lower part may need to be ground a bit so that they fit flat over the OM lower bar mount, but my friend here, who's bike this is, said it was an easy install.
I don't know if Puig makes a skid plate; I don't think so. But I've had their stuff before and I think it is well made.
Hope this helps.
