Just swapped-out my factory badges for the sexy 4-bar badge. I like to keep all the original stuff just in case, so here's a quick walk through with pics of the whole job:-
Needed:-
Some popsicle sticks
Small craft knife
Hex driver for original badge 4mm ( at least I think it is? )
Meths or alcohol
Hot hair dryer.
Maybe some acetone, but not strictly necessary.
Sharpen a couple of popsicle sticks chisel-fashion and use the hair dryer to get the badge hot enough to be just almost uncomfortable to touch .
Use the small hobby knife to gently prise up a corner of the badge inlay. This is a thin sheet metal inlay which is printed with the Triumph logo and it is retained by grey double-sided tape.
Once the corner is lifted, gently slide the popsicle sticks along under the perimeter of the inlay and apply more heat if needed. Just work along gently and avoid creasing the inlay.
Eventually you'll get there and expose the main badge retaining screws . Undo these and prise the badge off from inside so as to avoid paint damage.
You should now have intact original badges that can be kept or displayed in the man-cave, or woman-den , whichever it may be.
Needed:-
Small craft knife
Meths or alcohol
Hot hair dryer.
