Are there any available yet for the ST?
Excellent info here. I take it you're at Woodstock Triumph / HD? I suppose I could ask MCC in Villa Park where I bought my ST. ON the other hand, I spend some time in your area on a regular basis. Since you seem to know your stuff, maybe I should just ride out to you? If I do, who should I ask for? I'd also want front (progressive) springs. I'm approx 210lb rider. PM me if you prefer. Thanks again for this info.
Yes. I have my bike registered and ticket for Saturday. Look forward to this event every year. See you there. Thanks.I do work at Woodstock Triumph/Ktm/ Harley-Davidson. You are most welcome to ride out and see me or call 815-337-3511, ask for Matthew. You are also welcome to call me at my cellular which I will pm to you. Will you be attending Motoblot? I will be there all weekend stop by our booth.
http://motoblot.com/
https://www.facebook.com/woodstocktriumph/
$200 is the standard price for the Hagon road shocks. The Nitros cost just over $500. Once ordered from a Hagon dealer the shocks are assembled in California and shipped.Call Dave Quinn and get a pair of Hagon shocks for $200
He will make them to suit you with the proper spring rate and damping
Great to finally see a review on these, thanks! So that is a one touch adjustment for both rebound and compression?Just my humble opinion, but might be useful for someone...
https://www.youtube.com/watch?v=lWeLgiPN9bo&lc=z132s1w5hxn1yfzg504cifsjpq3qvbti1q40k
Yes there is no separate rebound adjuster, so you have the same rate of compression and rebound, but they work really well.Great to finally see a review on these, thanks! So that is a one touch adjustment for both rebound and compression?
That's probably the most common lock, but these have a pinch bolt to tighten the preload ring (it has a slit cut in it)I can't see any lock on the preload adjuster? Would be usual to have two rings to lock against each other.
Remove the kickstand, clamp it in a vice, and then use a breaker bar to bend the lever slightly. A couple degrees should be plenty. If you use a torch on the bend beforehand, you can anneal (soften) the metal somewhat and avoid a stress fracture.I've also lowered my 2017 Street Twin with 1" lower Ikon shocks that I love. They put on lighter springs for my 102lbs! Also slid the forks in the triple tree to match the 1". But now I have a kickstand problem and always have to park on the downhill since they don't make a shorter or adjustable stand for it. What are you doing about that?
Bending the metal is risky, that much is certain. If it made of aluminum, don't bend it. Bending is generally fine for steel though.Thanks Delta. Will have hubby try thatTriumph service manager told me he wouldn't recommend that but I'm sure he's not allowed to say anything much!
I went with the same Hagon 2810 shocks on my T120 and have been very happy with them. I ended up buying from Dave Quinn in CT but didn't know about Belacorse. The distributor here in CA, which is not too far from me, was crazy expensive.I put Hagon shocks on my 2016 Street Twin - TBH mostly to get LOWER bc I am a 5'0 female rider. I looked at responses to this thread on the forum and ended up chatting with 3 different distributors. I went with the Michigan dealer of Hagon shocks. That guy is awesome! He spent a lot of time on the phone with me asking me about my riding style, types of trips/luggage/passengers I might carry, my size/weight - he informed me without that "here little honey tone" that makes my skin crawl. He set the shocks exactly where there were best for me. I have my full foot on the ground so I can muscle my bike where I need to, yet I'm not bottoming out over bumps. My ST is taking the curves like the graceful lady she is. I've put on about 1K miles with them and they handle beautifully. I can't say enough good about my experience with the dealer and the shocks. They were less expensive than I expected - a lot less expensive - and super easy to install.
http://bellacorse.com/shop/parts-fo...triumph-water-cooled-motorcycles/hagon-2810-adjustable-shocks-street-twin-t120/
