Are there any available yet for the ST?
I've watched his (TECs) installation video on you tube he explains to make sure this bottom bolt is tight and check it after so many kilometers. and certainly I would lock tight it in any regard.I went back and looked at that photo a second time. You will notice that the large bottom locking nut that locks down the ride height adjustment is completely unscrewed and many threads down from the lower part of the shock that it should lock up against. Once ride height is adjusted Loctite should be applied to the threads and the nut tightened (as dscribed in the instructions that come with the shocks). There is the cause of the failure, improper install. Would happen to Ohlins if you left that step undone.
Yep that's them.Is this the kit in question?
http://www.tecbikepartsusa.com/TEC_Black_Front_and_Rear_Adjustable_Suspension_Kit_p/t-fras-b-st.htm
If so, they look kind of cheaply made. Despite the photos being absolutely tiny, and correct me if I'm wrong - you can still see the casting irregularities of the piggyback support arm, indicating a lower quality part. Everyone else is using billet aluminum for that part of the assembly.
With all the warnings I've read about TEC on these forums (calling them glorified Chinese knockoffs ....
Show me a positive review from an accredited source. I'm willing to listen.
Is your comment directed at me?My apologies, I am new to this forum and was not aware that I needed accreditation to post a review.
Here's a high resolution photo of an Ohlins piggyback rear shock for comparison:Yep that's them.
Best to use tube or better still a one piece die casting like TEC incorporating as much detail as you can just like our engines. The two tubes in these shocks are bored to size and threaded internally on a lathe.
Hopefully everyone takes price into consideration, money does not grow on trees. The TEC shocks do appear to give a nice bang for the buck for those looking for a stiffer spring to accommodate a pillion, which you clearly vouch for.Must add I only bought them to prove if the poor stock back end when two up was down to tyre or shocks. It wasn't the knock off Pirelli made in Brazil rear tyre after all. These TEC shocks have performed way beyond expectations. Particularly if you take their price into consideration.
Your own perceived difference in the manufacturing quality are evident. You openly base your evidence on nothing to do with manufacturing quality other than their appearance in pictures. There is much more to manufacturing quality.Here's a high resolution photo of an Ohlins piggyback rear shock for comparison. Note the high level of precision of the parts in question.
Now to our TEC, using the highest resolution photo I could find.
Not much more needs to be said, the manufacturing quality differences are self evident.
Simply no foundation for this statement other than your own perception from pictures and exposure to a whole load of branding and marketing spend about the yellow item but not on the other.... What we can determine objectively is that the TEC units feature less quality manufacturing processes than others, which is nearly a guarantee that concessions were made somewhere. How those concessions manifest and if you care is going to be up to the individual and their riding style.
But you have judged them on absolutely nothing other than your own perception of quality due to your perception of their visible surface finishes.Edit to add more photos. This appears to also be the TEC shock in question, at even higher resolution:
http://cx500forum.com/forum/attachm...nts/cx-customization-mods-forum/18630d1418570128-cx500-rear-shocks-imag0094.jpg
Note the imprecision of the milling cuts on the cylinders. Look at the rough finish on the castings.
I'm not trying to unfairly judge TEC, but these ......
Is there a reason why you cant say ohlins and refer to them as the yellow ones but have no problem saying tec? Just curiousYour own perceived difference in the manufacturing quality are evident. You openly base your evidence on nothing to do with manufacturing quality other than their appearance in pictures. There is much more to manufacturing quality.
The two shocks are manufactured with the same basic components. Coated steel coil springs. Aluminium cast bodies (not billet as you claimed earlier for the yellow ones). Chrome plated piston rods. Aluminium pre load adjusting rings running in threads turned on the outside of the shock main cylinder. The two shocks use exactly the same major parts and in the same conventional layout.
Without measurement of the tolerances and surface finish of the functioning surfaces and components inside, the colour and finishes of the visible parts is all we have to go on (other than someone who's ridden with them and knew how easy they were to fit).
There are no milling cuts on the shocks components. You might mean turning marks from the lathe tool where they are machine finished? I prefer a rough finish to an aluminium casting. Just as long as its smooth without blow holes and easy to keep clean and free from corrosion. Proves its made from a nice presentable aluminium casting using decent aluminium. Not a painted or anodised thing that might not be fit to be visible and contain casting imperfections covered by the false finish.
I think the TEC shocks choice of colours and surface finish are in keeping with the rest of the Street Twins design. IMHO can't think of anything worse than introducing another colour, particularly yellow and one that only serves to promote the manufacturers brand for them.
Areas I would point out on the yellow ones is the black plastic shroud on the tube adjacent to the middle of the spring. Usually this is to stop any leaning of poorly made springs catching the metal body of the shock when compressed as you ride over bumps. Good that they make contingency should this happen. They are not the shocks that go on the Street Twin either so just what we get when ordering is unknown. And the forked end on the yellow one in the pictures is poor design. The prong of the fork in the casting with the threaded hole is expected to bend at its join to the main tube top. This to pinch the spacer in the swing arm bush. Fine with steel forks on steel shock as steel has some flex. Poor practice with short bits of thin aluminium castings where they change to thick section that will be subjected to heavy and varying shock loads. And if the soft and too short length of female thread in the aluminium strips due to the slightest over tightening or binding of the pivot, the shock will detach its self if the bolt works out. Thank fully our Street Twins don't use that method of mounting the bottoms of their shocks.
See how they are nearly the same as the painted silver parts on the standard bike. Footrests and headlamp brackets the more visible items.
Nitrons are top notch, comparable to ohlins, Matris, Penske, Et Al, however within a price point you have to choose features important to you for your style of riding.ie: do I need independent rebound and damping control? or a combined rebound/damping control etc. Nitrons like Ohlins and others are custom configured for your riding weight,style, and preferences.Anyone used or know of someone who's tried on the Nitron Shocks? These seem to be pretty good, but can't find any reviews.
http://www.nitron.co.uk/catalogue_item.php?catID=13508&prodID=87592
Because he's a human, and inherently biased, so it reflects in his narration.Is there a reason why you cant say ohlins and refer to them as the yellow ones but have no problem saying tec? Just curious
