Which is better for general parking on a flat surface? I find I tend to use the center stand if I can when I park, but would the side stand be better?
Why, yes. Yes, it does. Although you didn't mention the bandoliers, it's the same outfit and helmet I wear on horseback, too.On 2007-04-16 15:55, bodpbucho wrote:
Side, the CENTER stand is less stable. btw: does your riding gear include a red speedo , and a revolver?
Jim
A guy in Montana who runs a company called Schneiders came up with a straightforward solution called the FatFoot. Bob
I agree from a physics point of view that a triangle is more stable. The load is spread out over a much wider area. If in doubt about the parking surface then place a metal plate or a crushed beer can under it. I've been doing that for 30 years and it hasn't failed me yet.The side stand plus 2 wheels forms a tripod - a generally more stable configuration. Obviously there are circumstances that may dictate one over the other (if you have the luxury of both). I agree that regardless of which is used, the ground can give way. Even many seasoned riders have fallen prey to the quicksand that lurks under every motorcyle.![]()
Ernie, you'll find with center stands, they are designed to utilise the fulcrum lever of the stand, so that the amount of lifting required is minimal. My old BMW K1200GT (300 kg) would roll onto the center stand via foot pressure on the stand lever, and almost no lifting at all. I can't comment on the Triumph Bonnie version, but I suspect it will be the same. And compared to a Beemer's weight, it's a babyQuestion folks,
I'm a little old guy and I haven't forked out the dough for a centre stand (should be part of the standard kit?) but I'm hesitant as will I be able to pull the brute up onto the stand?
Ernie
