How I get 8+ years from my motorcycle battery ("and you can too!" lol)
3.9K views 35 replies 18 participants last post by  adri
Sorry for the lame title, didn't know what to put and couldn't help myself tbh lol
This video covers seven of the things that determine a motorcycle battery's lifespan, and how to maximize it. Four of these battery lifespan influences are completely within our control, and the other three are good to know before spending money on a new battery.
It covers why the initial setup and charge of a new battery is crucial for its performance and longevity, how your motorcycle riding habits can impact your battery's lifespan, and the importance of good maintenance and storage.
For what's outside of our control I explain how battery capacity, type, and manufacturer choice all make a difference. I'll also explain why I recommend high-quality brands like Yuasa and Antigravity, and caution people against buying from fly-by-night Amazon and eBay brands with no website/office/contact/support.
Basically, I work offline in the motorcycle biz, and created a pretty comprehensive guide to maximizing your motorcycle battery's lifespan, because it's probably the #1 cause of people needing to spend money unnecessarily on bikes for towing and service. Hopefully this can help some people save some money and not get stuck somewhere.
If I missed anything or got anything wrong, please let me know and I'll pin a comment under the video to help other riders!
#2 ·
The only bike I've had on the road long enough to know the battery life is my GSX14 & that runs a Yuasa. It's now on it's third, fitted this month, at 22 years old. So I get approx ten years life by just using bike the bike regularly & nothing else. It's probably seen a charger three times since I got it in 2007, all after stator failures..
#4 ·
If your battery is in an unheated garage on a tender you must not in northern Canada. This winter on December 15 it was -45c without a wind chill, the high for the day -39c. It was like that for weeks. Even our SUV needed to be started and ran at highway speeds to help the battery and it was plug in with a block heater. Anybody who left their batteries in their bikes will be buying a new in the spring. Mine were removed and put on a charger downstairs. In northern BC we can’t ride much past October until April so it best to remove the battery. 6 years on the Triumph and 9 years on the BMW battery
#8 ·
10+ years from the OEM battery in a Sportster in a heated garage with a tender on one week a month over the winter.
7+ years from a replacement AGM battery, from the same OEM supplier, in that Sportster in a heated garage with a tender on one week a month over the winter when I sold it.
Poor quality tenders can cook a battery to an premature death.
Seems the secret to battery longevity is a quality battery on a quality tender over the winter.
OptiMate 4 Dual Program - OptiMate
#16 ·
This was the first purchase after getting my 2016 TTR, still OEM battery and every spring the battery turns over the crank without hesitation. Every day I go into my garage and see the OpiMate 4 is on and I can see the function being performed!
#9 ·
I had a stock battery in a ‘17 Harley Softail Slim that lasted me 4 years in an unheated St. Louis garage and on a tender when I wasn’t riding it. The stock batteries in both Sportsters I’ve owned both died after two years in the same conditions.
I first bought the Harley branded version of this and liked it so much I bought an unbranded one and hooked it up to my Thruxton RS.
#14 ·
The requirements for starting a 200cc Vespa are WAY less than that for a 1200cc twin .
Yes I agree but the battery is correspondingly smaller, it's only 2.3AH and 85CCA. Don't even have it on a trickle charger.
Why do you ride your Vespa so seldom? The scooters I've ridden over the years were always a blast to ride
Yes they are fun but I only drag it out for the occasional club treasure hunt and the odd charity event. I also have a 1960s Lambretta as well as my Speed Triple 1050 and a KTM 1290 SuperDuke which also needs a fresh battery every couple of years. The battery will start the bike but the electronics go awry if it's less than 100%. Random TRC errors and exhaust valve errors are the first sign the battery needs replacing. ECU and MCU threshold voltages are way too critical on modern bikes combined with a desire to fit smallish batteries to keep the weight down.
#15 ·
(1) I use the smaller 750-800 mA battery tender (ie not the common 1.5A model) this avoid battery boiling. (2) I use a digital timer that cycles the tender 75 seconds per hour (that's 30m per day) -- this avoids peak charging. Letting a lead acid voltage dip down is really bad for them, the trick is to not let that happen. Don't let it sit self discharging all winter, for a month, or even 2 weeks.
#17 ·
Terry Colly, you do know KTM stands for "Keep throwing money" My old TRX Yamaha that I register for three or six months a year I disconnect the positive terminal when rego runs out and give it an hour on the tricklecharger next spring and it's good to go. My garage doesn't get real cold though. Battery lasts about eight to ten years.
#19 ·
Glad to see so many people getting roundabout a decade out of their batteries! I'm in Toronto Canada which is more north than some, but apparently a lot less north than others haha. We get some real bad cold and long winters here and a lot of people neglect their batteries. I might get close to a decade out of mine, but I have plenty of customers closer to the 3 year mark.
Also just want to say thanks everyone for chiming in, it's been really cool seeing all of these replies. Thought I was the only one who cared about this stuff. Cheers!
#24 ·
I wouldn't ride very far from home with battery more than 5 yrs old. When the battery in my garden tractor dies I take the battery out of my bike that has the oldest one. Put that one in the tractor and get a new one for the bike. Batteries are cheap, after spending thousands on a bike why chintz out on a battery? I know Guzzi behavior. :ROFLMAO:
kk
#30 ·
I once had a Kawasaki 1500 Vulcan ( 1st gen., 4spd). That bike got ridden just about every weekend. Always bought Yuasa batteries for it.
The thing with that bike was the battery was only good for a year. Never gave an indication battery was going. First two times it happened bike cold started great then just randomly no juice on start up at some point in the ride.
It got so I marked the calendar when I put in a new battery and just replaced it twelve months later.
Everything else checked out fine on the bike.
Dealer found no issues with charging system and Kawasaki tech. support had no clue.
#31 ·
I am happy getting 5 years out of my original battery so far, it's needs a quick charge if I let it sit for 3 weeks but if riding all the time it's still good but it will be replaced soon before winter hits and I get new batteries for 1/2 price so not bad for me.
Getting 6 years + out of a battery well all I can say one day it will let you down without warning and you could be stuck somewhere far from help.
It only takes one cell to fail to kill your battery and they will do it without warning.
