Hi everyone , i have just joined this site and am hoping any usefull advice . I havent had a T140 before , (had a T100 about 40 years ago) and have now got most of a 1973 T140V brought back to UK from the states . It is now all stripped down for rebuild and engine on bench . My conclusions so far are that the 8000 mile on speedo is correct , that it had an accident fairly early in its life that smashed the forks and primary chaincase , that it was partially stripped for parts and has now had parts loosly chucked on to it to make it look like a bike again to sell, and i bet its over 40 years since it last ran.
So my question is about the engine , It looks like it has never been apart , even the timing cover and gearbox cover have never been removed since new and the bores look mint , no wear on cams and valve tops and i am reluctand to strip it down if it doesnt need it . My worry is how likely is it to leak oil from the crankcase join .There is plenty of oily muck on underside but that might be pipe joints as after market oil cooler was fitted
If i need to split it could i leave crank and cams bolted up and just strip all primary side and remove rotor to lift left half of crankcase away , Thanks Loz
