Hi,
Assuming your bike still has two separate ignition coils, one either side of the frame tube under the tank, I use the standard Triumph 60-2207 as fitted to the '71-on 500 ('71-on 650 are oil-in-frame, have the coils sited under the seat so use longer wires).
The wires should be insulated stranded copper wire conductor. The main thing to ensure is you're sold a set with coil terminals
and plug terminals crimped to the wires, the terminals are then covered by separate plastic
covers.
Ime, what you
don't want is a set with separate plug
caps screwed into the ends of the wires;
these are an unreliable pita, always coming loose, every now-and-then you have to cut a bit off the lead so the cap screw tightens, eventually the plug leads are too short and you have to buy new ...
It's been converted to electronic ignition.
Which one? Photo. of the electronics "Box"?
The important thing to know is whether the bike has specifically any digital electronic components - this could be the EI and/or it could be the regulator/rectifier. Reason you need to know is specifically digital electronics are more susceptible to electro-magnetic interference, the HT is a prime source of EMI, digital electronics need a 5 KiloOhm resistor in each HT circuit to suppress the EMI - I prefer it to be the spark plugs, they must have an "R" in their code - e.g. Champion RN3, NGK BR8ES.
Hth.
