Sorry for the lengthy writeup.
With everything initially connected the turn signals and relay all work as advertised. Once I get on the road the signals no longer blink individually left/right no matter what input I select. When the left or right input is selected, both turn signals turn on like a hazard indicator. Checked fuses and none were blown, but when I turn power back on after checking fuses problem was resolved. Until I hit the road again and the problem returns. Sometimes it will be right away or after 5 minutes on the road. Please help any way you can. I'm wondering if the issue is coming from the actual turnsignal button sending power to both signals instead of just one?
Sent from my SM-G955U using Tapatalk
