Triumph accessory installation instructions
12K views 4 replies 5 participants last post by  richreed701
Triumph has not so far provided any installation instructions for the accessories I have purchased for my ST. They refer you to www.triumphinstructions.com. I have been using this when considering accessories for information. You just need the part number for the item and input it and if available the installation instructions come up. I usually print these out (old school) and review them at my leisure. This way I know if the install is beyond my capability or if I need to consider a dealer install. It also shows if you need a separate installation kit.
#2 ·
Thanks for this - turns out the dealer gave me the wrong torque value for the engine mounting bolt that I am going to use for a frame slider. I figured that out by looking at the instructions for the dresser bars which use the same mounting position for the lower end. Just appalling that Triumph doesn't publish the shop manual for the ST.
#4 ·
I love that Triumph has a webpage just for that. I was running into the same problem as you. I couldn't believe none of the PDFs were uploaded yet for the new part numbers... THEN... Just for giggles & shiits, I typed the exact same part # in without the "A" at the beginning of it, and bam, almost every accessory I was installing on my Thrux-R was popping up... So try that 'tip from the pros'. Hope that helps!
  • Like
Reactions: richreed701
