Hi,
Can anybody offer any hints / tips on adjusting valve clearances on my 97 Trident ?
I bought a shim compression tool which ended up not being very useful as I simply could not get the shim out of bucket (shim was not pinced and could rotate freely).
As I found that I had 4 clearances out of spec, I pulled both cams from the head. Once the cams were clear I could easily remove the shim buckets to get the shims out to meausre them and then re-calculate what the new shim size should be.
Went to the local dealer, got some replacement shims, put it all back together (including the correct cam clamp sequence) and now I find (I guess I should not be suprised at this) that a couple of the previously OK clearances have changed (slightly).
It seems to me that pulling the cams is one way to perfrom this task, but the risk is that I upset another clearance elsewhere that was OK.
My head now has two inlet valve clearances set to 0.08 mm (which I understand should be in the range of 0.10 - 0.15) and on exhaust set to 0.22 (which should be 0.15 - 0.20). Whilst the exhaust is not so much a problem (may just make more noise), I don't want to risk an inlet valve seat being burnt out.
Should I be concerned enough to strip the bike down again to 'adjust' the two inlets back into tolerance (given that we are only talking about 0.02 mm error) ?
Can somebody also let me know what increments the cams are supplied in, I think it is 0.005mm does that sound right ?
Any wisdom appreciated.
Steve
Steve
