Torquing down brake rotors & sprockets (thread lock?)
11K views 12 replies 9 participants last post by  vitesse
I'm installing new wheels on my '13 T100 and need advice on installing brake rotors & the rear sprocket.
Do I use Loctite on all bolts? Red or blue? Do the torque specs account for thread lock? I've always heard to lessen the torque 10-15% when using a thread locker due to the lubing effects. I don't want to over tight & strip.
#2 ·
I apply blue to each screw in turn, thread it in, then torque the set crosswise to the specified torque.
Is this correct? I don't know, but I'm not going to drive myself nuts overthinking it.
#10 · (Edited)
I replaced the front rotor bolts with ProBolt stainless, which use a smallish Allen size in the head, smaller than the factory bolts. They deformed somewhat upon being torqued to the correct spec, which makes me think that they'll be a real treat to get out. :(
#9 ·
Red or Blue or Not
Mr. brock29609,
There is a thread locking compound on the rotor bolts from the factory. I would suggest using Blue Loctite when installing these bolts. I did use a little heat when I removed my rotors during a service. Do clean the threads, prior to installation, male and female.
As I remember, please correct me if I'm wrong, the sprocket Nuts are of a self locking variety and do not use or need a locking compound.
Go by the recommended torque specifications and don't adjust for any lubing effect.
Namaste,
Charles
