It's a savage way to test the product, but apparently this company does this test with all their bars.
I went with SW Motech also. Looks well engineered to me. I have not heard of any complaints so far with this crash protection.I have SW-Motech installed, Several off road drops. One hard. No issues at all other that scratches on the crash bars.
I installed the SW crash bars (bought them before finish reading about all possible issues…).I went with SW Motech also. Looks well engineered to me. I have not heard of any complaints so far with this crash protection.
After reading the entire thread I guess there is one failure for the SW crash bars but no where near the failures of the Hepco and Becker bars. I did purchase the HB hand guards but will be replacing those with bark busters now, sigh...Any complaints with the hepco and becker skid plate?
So I just picked up a ’21 RP. It’s in nice shape but has the dreaded H-B crash bar set on it. With only 6k miles on the clock, I’m hoping no damage has already been done.
First off, I would like to know if upgrading the bolts in the tank/upper bars to a proper fitting, higher grade 8 bolt would be a good fix. I read that the bolts that come with the kit are like a grade 5 that isn’t the correct length of shaft and threads.
Second, are there problems similar in the lower engine guards?
While I don’t “plan” on dropping my new scoot, I do plan on going off road on the SM1000 and SM500 (I live in Gatlinburg so the Smokies are at my doorstep) and doing extensive travel. I have friends in New England and Alaska I plan on visiting. (Ain‘t retirement fun?)
I want this bike to go the distance and from all I’ve researched it should be more than up to the job, I’m just on a fixed income now and have to watch my pennies. If a simple bolt upgrade and proper torque and installation technique does the trick then I’ll do that. If not I’ll pull the upper bars and remount the aux lights.
RD View attachment 802314
Hepco bars coming off asap!Congrats on the RP.
Get those Hepco upper bars OFF your bike immediately. Both of the bolts on my H/Bs broke off in the frame without ANY drop or impact to them.
Higher grade bolts are not going to save you the grief.
No bar is going to protect the bike from damage in all scenarios.
Another guy on ADVrider reached out to me about pulling the HB uppers off his bike (he also bought the bike used). Turns out the beak sub-frame was broken (one of the mounting points for H/B uppers)..no doubt due to previous owners dropping the bike.
Bars that mount to the upper cylinder/frame and under the beak are heartbreak just waiting to happen.
Smart move!Hepco bars coming off asap!
So now… any idea where I can source the stock aux light mounts???? Because I am the second owner and bought from a dealer… No mount is easily available…FleaBay?
And the stock upper motor mount bolts… I guess the local stealership?
Any help would be appreciated.
RD
Upper engine bolt failure:Crash bars have been a bit of an interesting journey for me on the Tiger (mine is an 850) I ordered and received the Outback Motortek bars and skid plate for the T850. Delivery took about five or six weeks, but as noted, they are in high demand. That was not a serious issue for me.
I did the install myself, as I've done before on other bikes, and I've also done all the rack installs and centre stand installs. I'm not an especially skilled mechanic, but I do have the necessary tools including a click-type torque wrench. I work carefully and slowly.
I had some fitment issues with the right side upper bar; the right angle upper engine attachment tab was bent too far, and so it did not fit. I fixed that by gentle persuasion with a small 5 lb sledge. Yes, gentle. It is also possible that the bike itself is not perfectly symmetrical and that the 2mm/ 1/8" adjustment I needed to make is a function of the bike, rather than the bars, but the right angle tab on the bar was less than 90 deg inside. I'm open to all possibilities here.
I watched the OM videos for the crash bar and skid plate install several times, and made notes before I started. I, personally, was not impressed or satisfied with the video installation. Too many things mentioned in the early parts of the videos are information that you need later, such as torque numbers. Also, the foot pegs on the 850/ 900 GT need to be removed to get at the lower engine through bolt. The Rally foot peg mounts are different and that bolt is accessible. Also, the upper engine bolts, 14mm hex head, are very hard to actually reach. I did it, but it was not as easy or graceful as it is shown on the video. Overall, it took at least 4 hours, with pauses, and rewatching of the videos, and finding the necessary steps required for the non Rally models; that is the sort of thing that a piece of paper in the package should address. Also there are some very close fitment situations, where the front cross bar bolts are 3mm/ 1/4" from the plastics surrounding the radiator; a bit of movement there and the bar & bolts might damage the rad or plastic shroud. That is just speculation on my part, and it could be solid and reliable, based on the product design and testing.
After I had the bars installed, I went our for a trip of about 2000 kms, a week or so. Upon my return, I removed the upper crash bars so that the dealer would have an easier time accessing wiring to correct a problem with the heated grips they installed. I found the upper left crash bar bolt missing. Later, the shop discovered that the bolt was not missing, but had broken off inside the upper mounting hole. I was very careful with torque specs and no drops other than gentle let downs on sand to practice picking the bike up.
I like the Outback bar design, and the protection seems very good. I'm less impressed with the installation process and the instructions, and a bit concerned about the bolts and attachments, but I think that various bar makers use many of the same attachment points. The upper front engine mounts seem to be used by all.
I didn't notice any change in the vibrations with the bars, but I have grip puppies installed. The bike is vibey at certain speeds, so hard to tell if there was any change.
@flyingburritobrother , I watched your video on the H & B bar problems. Thanks very much for that clear and calm presentation.
I spoke to Lorry at OM and asked him to make a lower set of crash bars that were just for the Tiger 900 Gt. He came back with their bars were for Rally and Gt models. How can that be if the Gt foot pegs are 2-2.5” more forward than Rally models causing a substantial lose in foot placement. These two bikes are of different platforms and should have there own proper fitting equipment.Crash bars have been a bit of an interesting journey for me on the Tiger (mine is an 850) I ordered and received the Outback Motortek bars and skid plate for the T850. Delivery took about five or six weeks, but as noted, they are in high demand. That was not a serious issue for me.
Wow didn't know that differences between the bikes, now I do understand why some people have clearence issues with their feet with some solutions...I spoke to Lorry at OM and asked him to make a lower set of crash bars that were just for the Tiger 900 Gt. He came back with their bars were for Rally and Gt models. How can that be if the Gt foot pegs are 2-2.5” more forward than Rally models causing a substantial lose in foot placement. These two bikes are of different platforms and should have there own proper ditto g equipment.
@Bawinn1
I think that you have correctly identified one of the issues with the OM crash bars that is ignored in the OM promotional and installation videos; that there are differences between the Tiger models, and that OM does not deal with those differences with their crash bar design. I personally found that the installation videos were not complete or comphrensive in respect of the various Tiger models. As well, I had fitment issues with my OM bar installation and had to go beyond the installation video for my own installation.
A secondary issue that your post reinforces is that Lorry does not deal with customer installation or fitment problems in a very helpful way. I'm not saying that he should do a custom bar design, but the 'one size fits all' statement doesn't seem to be reliable. That said, I do not know of differences in foot peg placement on different models. I'll accept this information for now and look into it, for interest if for no other reason. But if he says 'Rally and GT models' then that almost certainly must include the GT and the GT Pro, as well as the Rally and Rally Pro. And the (most excellent) 850.
Just musing here, but if OM looked at the bolt breakage reports, and frame movement and frame damage reports (for the Triumph Tiger 900 series bikes), and then reworked their product to address these issues, they could become a stand-out accessory company; there is a void for a super responsive and responsible company on this specific issue, and with some time and effort and money, they could dominate that space. And in doing so, they would earn respect that would be otherwise almost impossible to buy or claim otherwise.
First let me say that OM is on top of their game. I spoke or communicated with three people Lorry, Kassie, and Jason all who gave of their time to answer questions and address my concerns. Lorry went as far as to ask my opinion on the bolt problem. Kassie answered several emails and was always positive, and Jason gave me his cell number and-spent 30 minutes answering questions and addressing my concerns of fit and footing issues. I bought the OM Tiger combo had it still in the unopened box for two weeks before deciding to return it. I guess my final straw was I sat on a Tiger that was OM equipped and the foot issue was too tight for my likes or riding style.@Bawinn1
You must work for OM..... 😆So before you call or start that negative email think about this: Triumph can’t even made bars that work for the own bikes. Triumph needs to pony up and look at this multiple frame breakage and address it first hand before people, customers, riders get hurt.
What the heck? I did not here of any single stock tiger having frame issues, and I know a few that ride them hard, but I can find on all forums people complaining about broken bolts, and a few frame issues, when installing OM bars.Just to reiterate OM products in my opinion are still the best crash bars on the market at this time and the crew there are both friendly and professional.
New uppers? Where did you see thisWow didn't know that differences between the bikes, now I do understand why some people have clearence issues with their feet with some solutions...
I think I will stay wit the OEM solutions as there are proven and the revision of the upper bars looks promising
Ok, so I do not work for OM and ride a 2022 Tiger 900 GT Pro.You must work for OM..... 😆
Somehow this frame/bolt breakage is Triumphs fault when you've added rigidity where it wasn't designed to be? You've gotta be kidding me. This is the dumbest comment I have ever read regarding this issue. Sorry man....but adding the crash bars that mount to the upper cylinder mount point IS the problem.
It's beyond shameful ALL of these companies are still selling these products with a known issue.
Triumphs OEM bars do not mount to the upper cylinder mount.... (and I'm not defending them either given all the dents from their bars bending into the tank).
Anyone running any kind of upper crash bars mounted to the upper cylinder mount are sitting on a time bomb.
Saw some posts and also a few YouTube videos, the last I saw was from Vanesa Ruck, the girl on a bike YouTube channel, that did the 1000 dunas rally and the bike survived all the drops without issues.New uppers? Where did you see this
Looks like they are already out:Saw some posts and also a few YouTube videos, the last I saw was from Vanesa Ruck, the girl on a bike YouTube channel, that did the 1000 dunas rally and the bike survived all the drops without issues.
