You don't need the lengths. Since Pro-Bolt doesn't list your model pick a similar model like a 2013 Bonneville SE then go to Hermy's or another online parts lookup. Get the Triumph part number for a 2013 SE and for your 2013 T100 for front and rear caliper pins. If the part numbers are the same then buy the ones that Pro-Bolt sells for a 2013 Bonneville SE. Here, I'll do the work for you... 2013 T100 front caliper pin set T2020084 rear caliper pin set T2020966 2007 Bonneville front caliper pin set T2020084 rear caliper pin set T2020966 So all the Bonnevilles use the SAME caliper pins and you can go to Pro-Bolt and order front and rear caliper pins for a 2007 Bonneville SE model and they will fit your 2013 T100. Looks like SS front pin set is LSSPINBP003RZ1 Looks like SS rear pin set is LSSPINBP001Z2 Double check me to be sure. And Pro-Bolt shows the bolt dimensions.
URLs based on
@MarlinSpike's comment. I grabbed the dimensions from the pro-bolt site. Depending on your country it may not be practical to order from pro-bolt.
LSSPINBP003RZ1 Stainless Steel Brake Caliper Pad Pin. Manufactured from high grade 316 Stainless Steel to offer the ultimate in corrosion resistance. Sold here in our innovative DualDrive design, which benefits from an external hex for a socket fitment, and an internal Allen Key Drive. Each flat has been drilled to 1.6mm for ease of lock wiring as an extra safety feature. For those who truly value attention to detail. Why not make your calipers look like new again and replace the mounting bolts at the same time? Available for most models of caliper including Nissin and Tokico. Listed in model specific bike sections where fitment has been established or you can download the attached PDF which details a silhouette. Stainless Steel is also available in black, which not only looks great but has other benefits too.. This beautiful long lasting black finish results from an application of Diamond Like Carbon Coating (DLC) This gives supreme hardness and corrosion resistance provided by a nano composite coating, which increases the fastener lifetime dramatically and helps to prevent galling. By incorporating them right from the beginning, the overall system cost can be held level or may even be reduced. Please note that due to this special coating Black Stainless Steel is not identical to our Black Aluminium. Material: Stainless Steel Product Type: Brake / Caliper Thread Length: 10mm Shank Length: 48mm Head Height: 5mm Length: 65mm Socket Size: 8mm Allen Key Size: 4mm Pack Quantity: 1
LSSPINBP001Z2 Stainless Steel Brake Caliper Pad Pin. A replica of the original pin but in high grade 316 Stainless Steel to offer the ultimate in corrosion resistance. Why not make your calipers look like new again and replace the mounting bolts at the same time? Available for most models of caliper including Nissin, Tokico and Brembo. Listed in model specific bike sections where fitment has been established or you can download the attached PDF which details a silhouette. Stainless Steel is also available in black, which not only looks great but has other benefits too.. This beautiful long lasting black finish results from an application of Diamond Like Carbon Coating (DLC) This gives supreme hardness and corrosion resistance provided by a nano composite coating, which increases the fastener lifetime dramatically and helps to prevent galling. By incorporating them right from the beginning, the overall system cost can be held level or may even be reduced. Please note that due to this special coating Black Stainless Steel is not identical to our Black Aluminium. Material: Stainless Steel Product Type: Brake / Caliper Thread Length: 10mm Shank Length: 52mm Length: 64mm Allen Key Size: 5mm Pack Quantity: 1
