Status
Not open for further replies.
Rotella 5w40 T6
1 reading
15K views 48 replies 11 participants last post by  GearHd6
Howdy,
Just checking: does anyone know if that oil is NOT O.K. for our bikes? I'm coming from a 650 Vstrom where it is widely used and favored by many on the Stromtrooper forum. Is there anything unique about our bikes that would preclude it's being used, like a different rating? or?
Sorry, not interested to hear about how great Motul, Mobil 1, or Castrol is, or start a long drawn out oil thread. Just wanting to know if T6 shouldn't be used and preferably why.
Thanks!
Save
#6 ·
Unless they have recently changed it, I've used it in multiple bikes for years with no issues
  • Like
Reactions: Stevienh
Save
#12 ·
There are two categories: gasoline and diesel. Category S is for “Spark Ignition”, for Gasoline and category C is for “Compression Ignition’, for Diesel. For both, the letter S or C is followed by another letter. For example, SM or CF. The higher the letter, the more recent the technology of the oil. For recent oil, the higher specification will supersede the lower letter grade. For example, if we have an oil with specification SN, it can also be used for vehicles which request API SM, SL and SJ; it is backward compatible.
#25 ·
Check the bottle because there's no "S" cert on mine.
Not surprised due to formula, bottle and label changes. When Shell reformulates as was the Rotella line from CJ-4 to the CK (since 2016) the cost of recertifying every specification is obscene not to mention the time involved. As the re-certs are completed new labeling etc takes time.
As mentioned in my previous post all JASO oils must meet API quality levels of SH
#19 ·
Here's a thumbs down on the Rotella T6 diesel oil. Why? I used T5 for many years in various cars and motorcycles. I soured on T5 the first time I heard bearing knock at idle from my SV1000S. ***? The oil was fresh and the bike had only approximately 17K on the engine. I later confirmed that even MA rated diesel isn't a good choice for a motorcyle. One of my sources was - https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/ . I switched oils and there is no more bearing knock on the SV now at 24K miles. I'm running Mobil 0W40 European oiil designed for high revving turbo engines in both the SV and my TT600 with no clutch slippage. If you've ever seen an SV clutch you'd know there's nothing that could make it slip anyway. I'll take my chances on a clutch slipping in the TT in exchange for superb engine protection (see 540ratblog). Clutch plates can be rehabbed or replaced without too much trouble. Rings, bearings, etc. not so much.
Save
#44 ·
So you've rebuilt motors before? believe me if a bottom end bearing "knocked" no oil would solve that, it means at BDC or there about the shell is worn and there is no metal to metal contact until the surfaced move, you don't want movement. Could have been cam chain or other internals but not the bottom end.
#26 ·
I did a little research and found that the issue seems that the elevated level of zinc and phosphorous are a little high for SN so rather than try and hurt the flat tapped diesel market they make two oils. As mentioned JASO is a gas spec.
If you want to see the difference side by side https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4490450/Shell_Rotella_T6_5W40_CJ-4/SM_#Post4490450
Bottom line if you have a new car or bike that is calling for a SN rated oil and you have a warranty you might not want to use it. If your machine is a little older and calls for an older spec then you are fine.
#28 ·
So again, the typical oil thread which gets everyone nowhere. I'll continue to use the correct oil. I never understood how someone could spend $11,12,13,14,000 on a motorcycle but then cut corners on oil. If an oil company can't afford the correct certification then I'm all set not using their oil. I get the correct oil on Amazon for pretty cheap and I don't even have to go to a store to get it.
#32 ·
Look at my thread again. It isn't about affording the correct cert, it is about the EPA making changes in the oil and states like California not allowing older spec oils on the shelf. The current T6 has too much of some additive packages, though those are the same additive packages that people go after for metal to metal contact. (look into the flat tappet issues of about a decade ago) Diesel oil because of a lot of flat tappet applications is allowed higher amounts of those additives than SN rated oils. The debate is if those higher additive packages hurt catalytic converters or not. (I have a 30 year old pickup with over 200K that ran those high additive packages for decades and still has the original catalytic converter and still passes emissions with flying colors.)
I won't go into the debate that other additives can replace the zinc and the phosphorous and their effectiveness.
Basically what you have is a regulatory closing of a loophole. If you understand the chemistry feel free and safe to use the oil. If you don't or it does bother you to use spark rated oil then have at it. Do whatever lets you sleep at night. The reason I would still use it because I see it as a better oil than some of the "correct" oils.
#34 ·
2017 or not, there's still no "S" cert in that info. When push comes to shove and guys are trying to get stuff covered under warranty there's a good chance they'll be in trouble. I realize some of you aren't under warranty but a lot that lurk these forums are.
Save
#36 ·
Ahh, yes. Especially when you've done your own service. They'll want receipts and they'll also send out an oil sample. I worked in a Honda motorcycle service dept, the manufacturer wants a lot of information when it comes to covering warranty work like that.
Status
You have insufficient privileges to reply here.
