Rear Shock Adjustment
20K views 12 replies 13 participants last post by  Pdirdy
Anyone tell me where I can get the tool needed to adjust rear shocks ????????
#3 ·
Sure, your left or right hand. There is a tool, but it's not really necessary. Just grab and twist - that's how I do it. If you push up a little as you're twisting, it'll be easier.
#7 · (Edited)
There's an official tool, part number T2300995 but it's a very simple metal rod. A suitable tool can be made from an old driver with the tip ground off or even the allen key that we're given for seat removal will do it, or a 1/4" or 6mm drill bit (the blunt end) or a 6mm tent ground peg.
Is it possible that no modern manufacturer has seen fit to copy the old MZ's and BMW's built-in levers for no-tool, fast and convenient adjustment?:
#11 ·
I have no idea how y'all are doing the rear shock adjustment with just your hand. Do we have the same shocks?? I have a completely stock 2010 Bonneville, and there's simply nowhere to grip these shocks to turn them. The coil winds around the outside of the shock, and turns independently of the tension adjustment. I can turn it all day long, and it just goes around and around. In order to turn the shock manually I'd have to get inside or below the coil, a gripping area that would require superhuman hand strength to manipulate without a tool.
That said, adjusting the shock with any of the aforementioned tools is easy.
#13 ·
I've been to Amazon and returned! Thinking a 6mm round post spanner would do the trick....WRONG!!
Searched Triumph sites to no avail. Then I remembered when I bought my America, I joined Triumph Rat!
Bingo solution solved, a free (found one in my save it I may need it someday collection bin) 6mm round tent ground peg works great! With a little length cut off on the short end of the peg and some lifting on the bottom shock collar that has the adjusting hole and of course extra elbow grease, it worked just fine!
Thanks, Forchetto
