I've been struggling for the past few months to get a 1973 650cc (T120R) Bonneville, which I bought as a runner in need of a bit of tidying up, to run properly. Having changed the electronic ignition, fixed a non-functioning pushrod and cleaned and set up the carbs, I have reached a stage where the bike runs very well indeed from cold (although it won't tick over until warmed up, of course).
However, when the bike has covered (usually) about 15 or 20 miles and got thoroughly warmed up, the engine gradually becomes ever more 'vibey' and there seems to be a slight loss of power. The exhaust note seems to become a bit 'flatter' (for want of a better term) and acceleration is more laboured. If I carry on riding past this point, the vibrations coming up through the foot-pegs and saddle are so severe that it gives me blurred vision and a headache :frown2:.
The only thing that I can possibly think of is, if the valve clearances were too tight, the inlet or exhaust valves might be being held open and some power lost that way. I'm just not sure if that would explain the vibrations though!? Sadly, I don't think that this is the answer though because I recently set the valve clearances at 4 thou (inlet) and 6 thou (exhaust) to ensure that this wouldn't happen. (N.B. Previously, I replaced the two rocker box gaskets and didn't think to re-check the valve clearances. When I did check them, the inlet valves had no gap and were being held slightly open even from cold! Consequently, I over-compensated and set both pairs of valves at 2 thou more than the manual specifies and that's how they are set now, I assume).
So, I wonder if anyone can (following that slightly vague account of the state of the bike's engine :| ), offer any plausible theories as to what could be causing the engine to get much more 'vibey' after a long run? It's normally very civilised ... until it gets really hot :wink2: .
Thanks, in advance, for your responses :smile2: .
Andy
Andy
