Hey all! I've got a Street Cup with about 700 miles on it. I love the bike, although I've got to say it's had typical British reliability up to this point. The latest is an engine knock that comes after you get the bike good and warmed up. It only happens if you crack the throttle really aggressively, not in gear, mostly from idle. A good example would be rev match downshifting. It's just one knock and done but it's significant enough that you can feel it through the seat. Three times the bike has actually quite on me right after the knock. I can also reproduce it sitting at idle just giving the throttle a fast pull.
Took the bike in to my local dealer. They couldn't reproduce it the first time around but got it to do it when I brought it in a second time and more thoroughly explained that symptom. The ECU showed no error codes. I spoke with a shop tech and he said they were able to get their shop bike to do the same thing under similar conditions so they were chalking up to a quirk of the model. He said something about the ECU constantly remapping itself to adjust to the rider habits and that blipping throws off it's logic. Nice guy and we had a long chat but that seems bogus to me or, if true, a massive programming flaw on Triumphs part. He reset the ECU and some other electronic dohickies but that didn't solve the problem. Both bikes we're running 87 octane. He suggested bumping up to 93. I've done that and the knock still exists, if maybe slightly reduced (could also be the placebo effect).
Does anyone else have this problem on the new Street Twin/Cup/Scrambler line up? To me this seems like it shouldn't be chalked up as normal. Preignition can cause real damage over time. Its one thing to not ego blast with throttle blips at a stop light but not being able to reliably rev match downshift is a problem of basic functionality. The next nearest dealer is an hour away so I figured I troll the message boards before hauling my butt and my bike out there.
Sent from my Pixel XL using Tapatalk
