When I bought my 09 SE, it had (and still has) a battery tender cable directly attached to the battery. I then added a Garmin 590, which had a fused harness, so I attached that directly to the battery as well. Later, when I wanted to make a November run down to the NYC Marathon, I added a fused cable for heated gear (65W jacket and pant liners, which are actually used very rarely (once per season maybe), but when I want them, i want them now). Upon attaching the heated gear, I found that the battery terminal bolt would no longer reach far enough into the terminal to engage the nut inside the post.... my first hint that I needed to find a better system.
I have just purchased a Scottoiler e-system. This is the electronic version, that purports to use only a few milliamps of power. it is meant to be attached directly to the battery.....
I am now looking at Accessory Fuse Blocks and am interested in the Eastern Beaver with a 30Amp relay (I think that there is not enough power in the bike to drive the 50A). There is possibly enough room on the ledge behind the battery, or I might be able to find a sheltered spot underneath the battery box near the main fusebox (The airbox has been removed).
I have two questions: Is there a better way to do this?
For those who have installed accessory panels on your Bonnies: where did you put it. We are just not blessed with the same room that the V-Strom has in Eastern Beaver's installation guide. :headscratch
