The Satisfied Customer
So often these threads die out with no feedback or conclusion, so I figured I'd do a follow up.
As stated above I got the 520 Conversion Kit - SUPERLITE RS7 Steel Sprocket Set. I'm quite happy with it. 3 points I'd like to make.
The Positive. A day or two after ordering it I received a call from Sprocket Center telling me they didn't have the chain I ordered in stock. So they were going to upgrade my chain free of charge. The chain I ordered was more than enough for a Bonneville, the substitute is over the top for any perceived performance needs! Great customer service personally phoning me and telling me they were upgrading my order.
The Neutral. For whatever reason, I thought the chain came with a quick link connector. Nope it was a regular link that needed to be riveted. I didn't have a chain rivet tool. So that added 2 extra day's on by having to order it on line, as I couldn't find a shop open on a Sunday that had one. Seeing as I couldn't get to any shops the first 3 day's of the work week it was just as easy ordering it on line.
The Negative. This one in no way reflects on The Sprocket Center. The chain came coated in a thick sticky lithium looking grease that was near impossible to remove. Scrubbed as much as I could off of it before putting it on, and then with regular chain cleaner after it was installed. These things are meant to survive outside in the rain & elements, why does the manufacturer feel the need to put so much goop on it when a light coating of oil would have sufficed?
All and all I would recommend The Sprocket Center for quick and easy one stop shopping.
