When I first got the Bonnie a year ago, it has always been "cold natured".. I was told that the day I got it. I have read on here that it is the nature of the beast. Pull choke, don't touch throttle, hit starter,runs, then dies..repeat..repeat, and usually repeat.
I'm sure that I am not the first one to discover this. But in my searches I did not see this problem pointed out, so excuse me if I am bringing up something that has been well known to everyone but me. Perhaps this might help one other person out there.
There is a vent line running from the carbs down the left side of the engine. This hose is routed between the left rear of the engine case and the left front of the swing arm. This hose was pinched in between there.
I found it yesterday and this morning it is 28 degrees fahrenheit. I pulled the choke, did not touch the throttle, hit the starter...and its running. Wait for it....wait for it...it's still running... wow, it's on fast idle... Hey this things not stopping!!!
Yesterday after I repaired this, I took her for a ride. I did notice the idle is now a bit "stabiler" sp? Has increased stability... that's it! It has that now too!
Now I'll admit, I've done quite a few things to before.. I've put pipes on it, rejetted the carbs, bobbed the rear fender, lucas style light, headlight cut-out until start, horn relocate, nology coil, wires, yada yada yada... I've been around it a bit. But I had never noticed that hose before. If it had been a snake, it would have bit me. But no matter what, all through those changes, the hard cold starting has always remained exactly the same.
Poke sticks at me, make fun of me, but if this helps someone...awesome..
