Hi all , after a few rides & a few hundred miles i've noticed a bit of oil under the points cover (72 tr6r) which i believe means that the camshaft/timing cover oil seal(s) need replacing. Now never having taken this cover off before i don't want to mess up the timing if possible .So i'm thinking if i mark the back plate(i've got boyer electronic ignition fitted) and the inside cover before i undo the pillar bolts then match them up when i refit it ,it should be ok ?? is it that easy ? i believe theres 2 oil seals to replace ? fairly straightforward ?
any advice would be great .
thanks
bodge
thanks
bodge
