The needle taper doesn't start coming out of the needle jet until about 3/8 throttle.Between 3/8 throttle and 3/4 throttle,the needle position will have a noticable effect on the mixture.
Using no. 2 needle position doesn't usually cause any problem.
The size of the needle-jet will have an effect,even before the straight part of the needle is out of the jet.From just above idle to about 3/4 throttle,a worn needle-jet will richen the mixture.
It sounds like your problems are at 1/4 throttle,or less.Your slides should be no.3 cutaway.Even 3-1/2 cutaway will work,but it takes longer to warm up and respond.
Check the pilot jets first.A blocked pilot jet will make it lean at low throttle opening.A #78 drill ,or 0.4 mm drill,with an extension,is the best thing to check it with.A guitar string 0.016" or less,or even the 0.014" wire from a plastic bag tie will do.Pull out the idle mixture screw and the wire or drill should push into the carb body at least 1-1/2",if the pilot jet is not blocked.
An air leak at the flange O-ring,or around the idle channel at the float bowl gasket,will also cause a lean mixture at low throttle.The O-ring should be 0.100" thick,and there should be about 0.045" gap between the flanges.Don't over-tighten the flange nuts.
On the other hand,you could have a rich mixture cause by a worn needle-jet.This can foul spark plugs.If it's done 10,000 miles,it's probably worn.If you replace a needle jet,check the float level at the same time.
The best float needles are the latest aluminium ones,and the float level should be 0.080" below the float bowl surface.
