I was just wondering if any of you nay-sayers have used a reputable alloy rear sprocket made after 1985,or are your experiences base on the cheese/aluminium alloy sprockets made in the 70's
200+ hp world superbikes and 225+hp motogp bikes seem to manage with alloy sprockets that are of a lighter construction than the renthal sprockets I use,
I have managed 14000+ miles (still no signs of wear on the spocket) on a renthal alloy sprocket on a bigbore 130hp kawasaki zxr(zx7)
the advantages of alloy sprocket other than lighter weight are less inertia (not a reciprocal force as terry suggested), which manifests it's self as easier accel and easier decel, also less gyroscopic effect which means easier changes of direction.
don't under-estimate the effects of inertial force. why do you think wavey brake rotors were introduced? (not for any braking force benefits)
on it's own a change to an alloy sprocket may not be noticeable to the average guy, but if you've gone to the expense of light-weight alloy wheel rims for the above mentioned benefits, to not change to an alloy sprocket means you would not be getting the full benefits from the lighter rims.
