I recently "inherited" a 2010 scrambler that had the air injection disabled. However, when I got the bike the check engine light is on all the time the bike is on. It turns out that the person who blocked the air injection tube to the airbox also cut the wires to the solenoid and wired in a resistor which appears burned up and presumably is the cause of the error code to the ecu. The person who did this cut the plug off the wiring harness and threw it out and wired the resistor across the two wires going into the harness. So the resistor from Bellacorse isn't an option since there's no plug to put it into and my Triumph dealer says he can't get just a plug. So it looks like my only option is to replace the resistor. I've done some digging here and find plenty of references to the resistor but no specific info about type, resistance, or links for purchase. Can anyone provide info or help? Thanks!
