Hey everyone. I am shortly going to instal my new after market heated grips. So in preparation i am just planning what needs to be done.
I will use a relay with ignition switched 12volt. But I really want them to look more oem than after market.
So looking for a switched 12 volt supply, I came across this 2 wire connector ( see photos). It’s just hanging there sort of under the tank. A brown wire which has switched 12 volts and what looks like yellow with red tracer. The 2 wires go into a loom and cross to the left hand side and I think turn right along the left hand side fairing panel toward the front of the bike.
1. Any ideas as to why it’s there and what it’s for?
2. Could I use it for my switched 12 volt?
3. Could I get a male connector to fit it to save splicing into the brown wire?
Also in a photo is 2 bolts above this connector sort of on the base of the tank. I’d like to use one bolt to attach my relay to.
Finally,
Where is the bank of relays. Do I need to remove the rhs fairing panel? I was wondering if there was a vacant slot to plug my relay into. Maybe an accessory relay slot? This may have the benefit of already having a switched 12 volt supply.
Really appreciate any advice. .
Finally,
