101 - 120 of 168 Posts
Much thanks for the reply, DEcosse. I did the modification and the change is noticeable - it definitely feels a bit more responsive.
I do have a question, though. I used 12ga wire throughout, there's a 30A fuse in-line with + in a weatherproof ATO fuse holder and I my wiring is about 18" in length from the battery terminals to the R/R. Today, I went for a hard canyon ride and it was roughly 90-100 F out. I got back and checked the fuse holder and it was very hot to the touch, too hot to hold for more than a few seconds. Is this normal?
I thought I read earlier that some people were having the fuse holders melt, and that an ATO type was recommended. Any thoughts are greatly appreciated!
Thanks again, DEcosse. I clean out the terminals and wiped the fuse blades with electrical contact cleaner and applied dielectric grease. It still gets hot, but not nearly as hot as it did when I posted above.
I am using a Littelfuse ATO fuse holder, btw - in case it makes any difference.
The local Triumph dealer fitted a new (Triumph) R/R to my bike a few months ago, but it melted on my first ride.
Triumph provided a new one f.o.c under warranty and it's just been fitted. The charging voltage (lights off) was 13.5V
I made the bypass, using the power cable from a Motorola mobile two-way radio (you now know my line of work!) that has a moulded fuse holder. I replaced the existing 25A fuse with a 30A one.
The charging voltage is now 14.5V (lights off) & 14.3V (lights on). I'll ride the bike tommorow and see how things go (and I'll report back here).
My sincere thanks to the OP zam70, to DEcosse and to all the other folks who have posted on this most helpful thread!
Just saw this. What?!?!
Some great innovative methods for addressing the wiring for this mod.
Just wanted to give everyone a heads-up on a fantastic source for connectors - in fact you can get the specific one to match the OEM Triumph R/R plug if you wish to leave that intact.
This is the match for the 4-pin connector for output of the OEM Triumph R/R - http://www.easternbeaver.com/Main/Elec__Products/Connectors/250_Connectors/250_connectors.html - scroll down to the Yazaki 4PF250K-B - $3.95 (plus shipping for matched pair incl new terminal pins (which you can solder or crimp)
(Incidentally the one immediately above that in the page is the set used for the stator side of things)
Alternatively (if you are not averse to removing the original connector plug from the R/R) I would actually recommend this sealed waterproof connector - http://www.easternbeaver.com/Main/Elec__Products/Connectors/Sealed/Other/other.html - the very first one on that page, the Packard Dephi Metripack.
Also consider from same manufacturer this fuse-holder - http://www.easternbeaver.com/Main/Elec__Products/Fuseholders/fuseholders.html
Incidentally the guy who has that site is awesome - great customer service - even though he's in Japan (Canadian ex-pat), you'll have these parts in your hands in a week with extremely modest shipping charges.
For example, for the Delphi connector and fuse holder you'd be out the princely sum of $14.30 incl shipping!
Why is it that when I go to eastern beaver's site and add a $3.29 part to my shopping cart, the shipping is $165? Anyone know where to get a M/F set of Yazaki 3P250-CNA's in the states?
Once again, I can't thank you enough for your advice! I just ordered some 4ga welding cable for another of your mods! (The Furukawa's and Shindengen FH012 arrived today) There's a wealth of knowledge posted on this forum, a bit massive to filter through to find the real gems, which inevitably, include you! :bow
melted fuse box...
After 1 week of ownership mu fuse box has melted. Any way got another fuse box and a new mosfet rectifier and also did the wire mod. Bike runs nicer for some reason also starts first time. Battery is now actually getting charged when riding the bike.
Good mod thanks for the info. The fuse holder and lead can be got from maplins for ÂŁ3.
One question though the cables that have been bypassed are they dead now, mean the ones left in the loom?
DEcosse,
Thanks for your write up on page 4 of this thread. I used your Charging System Diagnosis thread to determine my rectifyer/regulator and stator were both ok and working properly. But I wasn't seeing enough voltage at the battery. 12.7 vdc at idle, and only 13, barely, under higher rpms. I had what I was supposed to have at the R/R plug, so I performed your upgrade to bypass the wiring harness, and bring the electons straight back to the battery. Success! 13.5 vdc at fast idle, 14.5 vdc with a few revs, at the battery! Right where I need it.
Thank you!
Hmm, I wonder if this is what my issue is. I know iv found my battery slowly decreases over time and gets harder to crank. I had cranked perfectly fine earlier in the day multiple times, but the other day while on the way home i had to pull into the median on the highway for something and turned off the bike. Would you know it I couldnt get enough out of the battery to start. Got jumped off and later that day charged it. Havent had any trouble since.
.....you will.
I you'e a single stator winding or windings on their way out this will cause slow battery charging leaving the battery to make do with 13-13.25 vdc when 14-14.75 is whats needed.Marginal stator can be hard to diagnose wihout proper info and tools
Just popping in to say thanks for the thread. I'm replacing the alt, reg and battery this weekend along with a rewire of the charging circuit on my Speed Four. Hopefully it will supply enough juice at low revs to help the fuel pump out as there seems to be a crossover point at 2000rpm where the battery can't supply enough juice and the alt isn't making enough power yet. Result, insane kangarooing under 3k and horriffic fuelling round town accompanied by a barely controlled and sudden rise in revs once the alt is making the power to feed the pump.
This is how I prefer to do it - cut off the output plug & splice new wires to go directly to the battery
But here's a good alternative solution for those who don't wish to cut their OEM harness in ANY way
- I happened across this on a TL forum site in this thread.
Pics & concept are all down to the original author, I am just relaying here for convenience.
Personally I'd rather make the permanent connection as per my post above, but I can see why some would not wish to cut their wiring and this is a practical solution to that.
This simply involves making a small adapter harness that goes between the R/R output plug (the 4 pin plug with the red & black wires) and the battery.
I would probably choose larger gauge wires & keep them as short as is required but the premise is generally pretty good.
Simply make up a positive lead with the Fuse holder and battery terminal ring lug, leading to the two wires with the female spade connectors which will connect to the two pins with the red wires in the R/R connector plug.
Then similarly, but simpler because there is no fuse, make the ground harness. I would prefer black wire myself!
You will want to make sure the spade terminals are tight on the connector plug pins - squeeze them gently with a pair of pliers if necessary to ensure they are snug. I would then wrap the plug in insulating tape to ensure that the connection is both secure & well insulated/water-proofed.
Here are the pics -
As echoed by many on this thread, thanks again to everyone who have posted all of these great tips on here. I plan on doing this to my Sprint, however I'm a complete electrical idiot and this all means nothing to me, lol... Hopefully I can find someone here in Colorado that can help me out with this. Mechanically I'm good, but anything with wires...ugh...
Add me to the list of happy campers after modifying the charging system on my Daytona. She started up on the first punch of the starter button in 40 degree temperatures. That's a first since the 1 1/2 years I have owned 'er!
