So while I recognize this forum is under the Speed Triple heading, since TuneECU also works for the Street, and there doesn't appear to be a TuneECU thread there, here goes. The manual for my 2010 Striple indicates the bike is designed to run on 87 octane fuel. To me that means the easiest power gain available is to advance the timing a few degrees and run on higher (93 for example) octane fuel. Has anyone tried this on a Striple? Given that the engine is tuned for 87 octane, there should actually be room for significant improvement and I would think advancing the timing across the board by a couple degrees should be safe, right?
