Hi all
An someone explain the benefit of buying a TTP map over using one of the free Tune ECU maps.
Lanark
Lanark
Tune 12 is for no airbox (assumed since you're using 11 now) and shorty mufflers.Hi Ash,
I just bought a pair of Stubby can mufflers. Which tune map do you recommend for it? Currently I have a 2010 Bonne w/Predator pipes.
And I'm using TTP Tune 11.
thanks...
Everyone I know who has gone for the TTP map has come away completely gruntled.TTP is the greatest, not one disgruntled customer and a bargain at $125 - $150 US?
I would say the same, I'm by no means an expert I just followed the list of mods on the TTP website n picked the appropriate one for short free flowing silencers.Tune 12 is for no airbox (assumed since you're using 11 now) and shorty mufflers.
TuneECU has an easy-to-operate throttle body balancing function. Takes just minutes to carry out. Much easier than messing about with vacuum gauges.With tuneecu, is there a way to balance the throttle bodies, or old fashioned vacuum gauges good enough?
Good question! I too am looking at several options for a tune. From what you observed, I'd say it's blocked.I have loaded the Tune#1 from TTP via their software, all seems good.
However, the TTP map install software is very basic. I ran the TuneECU software for more options and it comes up "No MAP".
My question is when you download and install the TTP map via the TTP software, should it be able to be seen in the Tune ECU or is it somehow protected from displaying?
Thanks for any help.
Hi ForchettoTuneECU has an easy-to-operate throttle body balancing function. Takes just minutes to carry out. Much easier than messing about with vacuum gauges.
Connect-up, start engine, click on "TESTS", tweak the balance screw until the two combined analogue/digital gauges at the top left of the screen read about the same:
Is that all? Sounds so easy even I couldn't mess it up!You can take your map and change it for your current setup. You un-check the boxes for SAI and O2 using tune ecu save the map on your laptop/pc and then load it over the one in it now. Just name the file something you will recognize as having made changes. It's pretty simple really
