The OE bar angle is familiar to me because it is very similar to how i set up the Gilles Variobars on my 675 Daytona. The OE 08 Daytona clip-ons were cruel punishment, and the variobars without riser were so much better and somehow reduced vibration. I already put thicker softer grips on the RR which helped with the terrible vibration, but I thought i would try Gilles Variobars on the RR hoping to further reduce vibration. I have measured and drilled the locating holes for the switch pods and 2 for left side plastic grip sleeve screws. Without risers, the inner bar end will be lower, while the outer bar end will be higher. I will try it like this and get risers if needed.
