81 - 100 of 120 Posts
I decided to give the bike a good run, and I got 145kph in redline in 2nd gear
Heya.
I'm from NZ (Hamilton) and am interested in de-resticting the 2019 street triple I've just bought. Would you be interested in helping out? I cant seem to find the app to download to be able to do it. Do you still have the OBD plug also? Would you be interested in either selling it or maybe even flashing my bike? Dont mind paying what its worth :)
Any help is appreciated.
Scott
Heya.
Scott
Is this a 675 ST or ST R? What is the vin? You download the app from tuneecu.fr. You pay for it with PayPal to the author’s email. You will have to buy an OBDLink LX BT adapter. The process is complicated. The instructions are on the TuneECU Facebook page under files.
Hi guys, im in NZ and wanting to de-restrict my 2021 660 street triple however im not good with computers and am thinking about ordering the de-restriction kit from the UK.
Part #A9638267
If i install this part does that mean i do not have to take it in and flash the ECU?
I have read through this forum and have not found a yes/no answer to this so any help would be very appreciated
Thanks in advance 👍
Part #A9638267
Thanks in advance 👍
So it’s restricted in the hardware? Just to be clear, the full power 660 is 70 kw? Yes, you will have to put an unrestricted map in with TuneECU. The restriction is in the ETV2 table. See my last post.
Okay so going with the info i have the de-restrict kit is not plug and play? Seems like there would be no point in having that part if i have to change the tables regardless. I don't mind forking out for the part as long as i don't have to take it to a shop.
................in NZ and wanting to de-restrict my 2021 660 street triple however im not good with computers and am thinking about ordering the de-restriction kit from the UK. Part #A9638267..............................................................
I understand that de-restriction kit can only be used on the A2 versions sold in UK and Europe. The engine used in the 660 Street Triple, 660 Trident and 660 Tiger is restricted for the LAMS rules in Australia in an entirely different way to the A2 versions sold in UK and Europe. Pretty sure I read that the New Zealand LAMS version is the same. The ANZ version is specifically locked and even has a different restricted power output to the A2 version. Read this thread throroughly and see if the work done by the op, Billy Goat, will work for you.
Hi i did enquire with the company with my VIN# and explained i am in NZ and they told me it would work with my bike. However my only worry would be that i fit the part and find out i need to get the ecu tuned in which case i could save the $400 and just get it tuned. But finding it hard to find someone with the tools needed.
I will continue to hunt for someone who can do it around my location just thought i would see if someone had more info than just going through Tuneecu..
Thanks for your input.
Nailz11 on this thread put in an unrestricted map but the power didn’t change, so you need that hardware, assuming it removes the “governor@. The remapping is probably only in the ETV table(s). If you PM me your vin, I’ll check out the 660 maps.
I already downloaded the map, haven't got tuneecu or the bluetooth dongle yet.. i have found a guy who can do it but the location is whats getting me at the moment, will see how it goes 🤞 thank you for your input.
Isn’t the new Street Triple 765? The Trident is 660, no? Anyhow, you should be able to copy the etv tables from the corresponding all markets map.
I got mine recently and the vin number does not end with 6 numbers. The last 6 characters are 2 letters followed by 4 numbers. Not sure which map to download. Aus/NZ 2022 Street Triple 660 LAMS/A2
Are you guys sure that only changing a map
Have you seen the instructions for the kit? It derestricts the grip throttle position sensor. The instructions tell you that you also have to install the unrestricted map.
