Have any SS owners looked into this yet?
Please go post a video of it to YouTube ASAP. I just ordered mine today and cannot wait. Where did you get your exhaust wrap? I like the ideaI installed the FreeSpirits DeCat from A&J Cycles. It went on easily and the SS now sounds like a motorcycle should. At idle the sound is a noticeably louder, but under load, when you open the throttle and run through the gears, the sound is really sweet.
I had always planned to wrap the headers so the visible weld isn't an issue for me. I only had black tie straps, but I've ordered some gold ones that I think will look better.
I had the dealer install the Arrow exhaust Map a couple of months ago. The difference I noticed with the new map was the sound during downshifting. It went from a lot of popping to more of a gurgle.
Next... I have to do something about that plastic bash plate.
That is odd because @NKZY has the accessory tune on his 17 SS - with the actual V&H high pipes that the off road tune was designed for.At my dealership right now, and they can't load up the tune. ABS module conflict. Makes sense since you can't turn off ABS on the Street Twin but can on the Scrambler
It isn't called "off road" anywhere other than colloquially. In the software, it is listed as "Vance & Hines High Level Accessory Exhaust" or similar. Someone even posted a screen shot of the software and the available tunes that are listed, a while back.My dealer never said specifically "off road tune" but they did say they have a tune for my bike which is catless.
