Has anyone looked into the bonneville 14.5 ltr tank fitting in the speedmaster?
150 km per tank??I rode my 2018 speedmaster across Canada and back. Total mileage 12000 kilometers. The only thing you must be aware of is that your Speedmaster tank will do approx. 150km per tank. I think most modern countries have fuel facilities within this range. I was going to put a spare emergency bottle of fuel but thought I would never be needing it because I would stop at the next town, top up the tank and then ride on. Also even with a Corbin seat, it's still was good to get off the bike for few minutes every few hours.![]()
Sure.Yes you are correct. I use 150km as a safe distance. Of course you can get a bit farther but I do find it nerve racking if you are watching the reserve lite as you frantically look for a gas station cursing yourself for passing that last gas station just because they did not have premium. True story![]()
Your usual activity with the ADV is sit over it, press start, and don't stop it until the mileage counts 500, doing all the way without passing near one single gas station??200-220km per tank here, too, just to add to the database.
I admire the folks who are not bothered by the range. I guess I'm spoiled... my ADV bike will go 550km or so. For me, every ride on the Speedmaster requires a gas stop, which takes a bit of planning where I live. I would have put this on the bike's (very short) list of deficiencies.
I have seen only once, in pictures, a speedy with the biggerbobber tank.Interesting that you checked into that. I was interested as well when I first learned of that tank. But that tank is not really as visually suitable to the Speedmaster. For me, as for you, range turned out not to have been an issue, and the existing tank looks proportionally correct for the size of the bike. Personally, I'm glad I kept the tank as is.
I imagine you will enter into rage for me commenting, but what cools the pump is the fuel moving inside, not by being immersed inside the fuel around. That's why you should not try run the bike with tank empty of fuel, as it could overheat, but no reason to keep much spare fuel - The pump gets cooled exactly the same in a full tank, than with only 1mm over the intake line.This was my point about planning. I'd say, too, that it's worth remembering the fuel pump is cooled by being immersed in fuel, so riding the tank empty isn't a habit I'd make.
This is incorrect information. But I'm not going to let you draw me into another gaslighting episode to feed your need for attention. Ride your bike as you wish. I'm quite confident of my qualifications to offer that advice.I imagine you will enter into rage for me commenting, but what cools the pump is the fuel moving inside, not by being immersed inside the fuel around. That's why you should not try run the bike with tank empty of fuel, as it could overheat, but no reason to keep much spare fuel - The pump gets cooled exactly the same in a full tank, than with only 1mm over the intake line.
In fact due to fluid physics air and liquid inside a tank full of fuel will have a slightly higher temperature than an almost empty one with same environmental conditions - but either way only a few degrees more, nothing to matter.
The reason fuel pump is usually placed inside the tank is saving space, and reducing risk of fuel vaporization in previous aspiration by cavitation. Not because they keep cooler into the fuel.
I mean with this clearing, if you use to do like always refuel when you still have one third of tank or something similar to avoid overheat risk, no need to - as long as you keep it not going the remain distance number to reach to zero the "cooling level" of the pump will be exactly the same when it says "200 km to empty" than when it says "2 km to empty".
This is baiting and disinformation, not constructive discussion....NOT ONE SINGLE known statistic or studies ...
...Not one single manufacturer, not one single brand ...
I know a guy...
Where was this spirit of tolerance earlier in the thread? Someone wants information about extending their fuel range, and instead you tell them they don't need to and mock anyone who disagrees. Other people agree that the range of this bike is sometimes inconvenient, and you dismiss them based on your own good luck and no knowledge of who they are, how they ride, what they enjoy and care about, or where they live.... his own use for his own reasons... it is always 100% respectable someone to say "I prefer to do things that way because that make me happier/quiet of mind...
