Spark plug sockets
7.6K views 24 replies 14 participants last post by  jtho
I purchased an 18mm socket for my Bonneville that is actually made for spark plugs, supposed to be thin walled, but it still won't go down onto the plug far enough because it hits what's left of the AI tube alongside the plug.
I did get one of the plug wrenches like what comes in motorcycle tool kits, where you put a rod or screwdriver through the holes to turn the wrench. It goes onto the plug, and works for removal or installation, but with no way to properly torque the plug.
Just wondering how you guys get around this. Does anyone know if there is an actual plug socket that will work, so that I can use a torque wrench with it?
#2 ·
I wouldn't bother with the torque wrench. Turn in a new plug to snug, then another 1/4-1/2 turn to seat it.
#3 ·
Hi
Traditionally ‘standard’ (14mm) spark plugs use a 13/16" hex size, that = 20.63mm
The smaller than standard plugs (10mm and 12mm) traditionally use 5/8" hex size = 15.875mm
The latest very small plugs (8mm) traditionally use a 13mmhex size
Even though the thread sizes are metric, (14mm, 12mm,10mm,8mm) the spanner sizes are imperial (8mm the exception).
Regards
Peg.
#5 ·
But our twins use 18mm spanner.
  • Like
Reactions: Biker Guy
#9 · (Edited)
To be clear, the hex head / socket size is 18mm. That's what the Haynes manual calls for, and that is the size of the one I mentioned in the original post, which actually does fit.
I've had bikes since 1970, and I always just did it by feel, as some of you mentioned. I just got new torque wrenches and was wanting to torque them as called for, but with no socket that will go on a plug, I'll go back to doing it by "feel". Thanks for the remarks.
#11 ·
#23 ·
My XRV650 and NTV650 use the same socket, they use the same dpr8eix-9 plugs as my T100 too.
Just a little tip that applies to many applications.
A piece of rubber tubing over the end of a spark plug works great for feeding the spark plug down into some tight deep spots, and threading into the head.
The silicone rubber hose from a Stahlbus oil drain valve fits nice and tight on the ceramic insulator of the plug.
I already have the TPP SAI blanking plugs fitted so it's quite easy to change the plugs with the tank fitted.
#14 ·
I had exactly the same problem, couldn't find a suitable plug socket in my area, and I didn't want to faff about online and pay £8.45 (around $10) for something that cost about 20 cents to manufacture - so I made my own, using a very cheap generic 18mm plug socket from a lawnmower shop .... little bit of welding involved, and I covered the finished article with some heat-shrink tubing to make it look nice .....
#15 ·
Looks like a good idea lobsterbush. I'm not sure how much money you saved when you add up the prices of the wrench, bolt, nuts, shrink wrap, welding rods, and time ... but hey, if it gives you the ability to use a torque wrench, then great! And very innovative.
I'm using the $8 wrench like what comes in bike tool kits, and winging it by feel on the torque, but I'm thinking of taking the actual spark plug socket that I bought, and trying to thin down the walls a little with a grinder to see if I can get it to go on, because it seems like it's just a hair too thick to go over the plug. It may work, or I may ruin the socket, in which case I'll just keep doing it by feel.
If I make it to Home Depot, which is not really nearby, I'll try the Husky socket mentioned above by MarlinSpike.
Thanks for sharing your project, lobster.
#16 ·
A piece of rubber tubing over the end of a spark plug works great for feeding the spark plug down into some tight deep spots, and threading into the head. Also works for removing the loose spark plug if you have a socket that won't hold the plug.
In some applications, the spark plugs are really buried.
#17 ·
In terms of sheer economics, Biker Guy, it would have been better to just go out and buy one - but I like making my own tools, and I'm fortunate to have some fairly expensive equipment, such as welders, lathe etc, which I like to put to use rather than seeing it gather dust - OK, a plug socket is no big deal, but some things you just can't buy, like a toolbox for my America - the only tool you get with the bike is a lousy allen key that clips into the fuse holder compartment - so a couple of years ago, I made my own toolbox to fit under the rear rack, in otherwise unused space - see pics - it's still there, still watertight, and still looking good. I did post details on this site, in 2020, titled 'mother of all toolboxes', if you're interested ......
#22 ·
My solution was 38 buck or more from Snap-Broken truck. Ouch I thought he was kidding me at first but I was on lunch and didn't have time to argue with the guy and I had to chase him down to begin, with but the ones I had at home didn't fit, so I paid through the nose and now its part of my 30 year old set.
