I'm not sure what program you're using since I use OBD Link LX for my 2022 XE Scrambler. Try disconnecting the battery, wait a few minutes then re-connect and see if this clears the code.
Ok, your using an ANCEL Diagnostic Scanner which I'm not familiar with. Again, I'd try disconnecting battery then re-connect and see if this code resets.
