I actually had a problem with the standard crush washers from the auto parts store on my 2016 R. The threads on the drain bolt didn't go all the way to the flange, so when I tightened the bolt, it was running out of threads before it got really solid contact with the crush washer. The torque on that oil drain bolt is only 25Nm, and I think I was reaching that value with the threads just ending, not with the flange of the bolt really contacting the washer very well. It looked OK, but it very slowly dripped oil. Like one drop every day or two. Who knows whether I lost any while riding, but the oil was never low, just an annoying oil spot on the garage floor.
The genuine Triumph washer is 3mm thick, vs. 2mm for the generic ones that I had, and that solved the problem. I've always wondered whether that was deliberate engineering on Triumph's part, to force me to buy their genuine Triumph crush washer, or just a manufacturing tolerance issue on the bolt on my bike.
