New chain install/Motion Pro PBR tool. ?.
4.5K views 11 replies 4 participants last post by  El_Destructo
I have a MotionPro chain tool, not sure if it's the one you have. Mine is not for Quad Stake Riveting. I thought that tool was for solid nosed riveting, not hollow rivets. I measured the chain width as suggested using vernier calipers. Outer surface of link plates. I did find an issue with the chain tool. When flaring the rivets, the instructions showed the large alignment bolt pressed up against the link plate with the flaring tip inside pressing on the rivet end. The problem was that the alignment bolt started to turn as I turned the push bolt to flare the rivet. This, started to press in the side link past my previous setting. I stopped when I realized what was happening. I remeasured the chain width and sure enough it was thinner on that end of the link. So the plate width was slightly tapered on the master link. The link was not binding so I decided to leave alone vs buying another master and redoing. Not sure what the ultimate wear or performance will be because of this.
I used a D.I.D chain and the flaring width for a 530 chain was 0.224-0.236". I made the flare ~ 0.228".
I don't disagree with you about replacing the master link. It is 0.002" out at the tight end. I'll see. This is on my Daytona which has been off road all summer for major servicing. Been riding the Thruxton. Now the Thrux needs a new chain. It never ends. Unless I buy a shaftie.
Okay, your tool will flare both hollow and solid rivets. The stock rivets on the chain are solid. Either way, just be careful when you flare that you are not also pushing in against the slide plate. The 4 cornered flare is for solid rivets.
It's not that difficult really, just a bit fussy that's all. D.I.D sells their own tool for their chains and there is no guessing or measuring. The tool has stops that won't let you go too far. There are plenty of Youtube vids on the subject. Doesn't have to use the MotionPro tool. The procedure is basically the same no matter the tool brand. Between some generic vids and the MP instruction sheet, you should be good to go. I'm doing my Thrux soon, if I had a video capability I would shoot the process for you.
