Anyone install the Motone fender elimination kit? I like how this kit includes the turn signal attachments. Any opinions how this one compares with the British Customs or Maund etc.. Thanks!
So there you go, next batch should be better!Hello mate,
thanks alot for your feedback, yes in fact I just fitted the kit to a 2014 T100 last week.
We originally designed it based around the 2004 frame, its largely the same but I note an increase in electronics and other things with the newer bike.
I will definitely revise the design on the next production, increase the space at the sides for the cabling and the bend angle didnt seem quite the same for the front bolts on the 2014 as the 2004,
thankyou very much for your feedback and time
Sam
Yep, shifting the whole assembly backwards to line up the rear bolt holes was my main problem too, no clearance between the two sub frame tubes and the outer rear edges of the plate. Hence the dremelling. I also knocked a bigger bend angle into it with a hide faced hammer. Didn't need to use longer bolts that way.I had the same problem. I also noticed that I simply could not get the plate up between the frame tubes and close enough where the plate with the spacer would be up against the frame, which is also why the bolts are too short. But with longer bolts it works.
No negative feedback from my customers since the re-design. I always take that as a positive sign.,Anybody installed this recently
