Kickstand under NEW Footboards
763 views 17 replies 6 participants last post by  variablediju
Ok so I got footboards with toe and heel shifter on it works great love it but Triumph didn't really think about the kickstand is now hidden underneath the boards and very tricky to put down
Does anyone know of a part that can help with this?
#3 ·
Mine is also like steve's, and never had any issues with using the kickstand. You use your heel to push down the kickstand, and there is plenty of space for that. It is that way in every bike with floorboards:
To recover it you use your tiptoe to pull:
#15 ·
no there is no fix to this that I've found
That's a shame. Try getting a short piece of hosepipe and fitting it over the extender piece. Does that help? I suggest this as an experiment, not the final solution.
I really do not get your point of difficulty.
I have never had such troubles, except maybe a bit of try before for the first few times when bike new for me. And I would say rather to recover the sidestand than to put it down.
System is pretty exactly the same as in the two bikes with heel-toe platforms I owned before.
I need no special effort even to make the pictures I posted, using both hands to handle the phone.
It's all a matter of pointing left foot out, placing heel in the area near the rear gear lever near the crankcase, and push down. Easy and fast. I can't even imagine a personal measure or limits issue that could make that hard as foot position is not rare or requiring any torsion - almost exactly the same point you place the toe in every mid control bike, but a bit lower.
A bunch of times pals (some clearly smaller or bigger than myself) that never used a platform before tried the bike and my simple instruction like "bring your foot to rear and push down" made a full result and comments like "ah, it is very easy" - never anyone finding himself in a situation like not being able, needing my help or something similar.
I would bet you are thinking it "harder as it really is" trying to set up a strange position, trying to do it watching with eyes where you put the foot instead of simply using your body memory...
#17 ·
I do not pretend to make you feel awkward. Simply notice there must be something you are missing and should be a way to make it simple (or find what is working wrong in your bike)
Did you see my "step by step" pictures? What exactly avoids you to follow that way or makes it hard? :unsure:
