Well of all things to go wrong... the key managed to break whilst turning it and locking the handle bar, leaving the main key shaft inside the barrel.
I can still use the remaninder to turn the lock, but the bit thats stuck in - how to get it out? I've tried fishing it out with a bit of wire, needle-nose tweezers, but its stuck in there presumably by the lock pins.
Is it possible to remove the barrel and poke the broken bit out from another angle? Looking around it seems you have to be careful not to lose the pins, but I wonder if you can even get access from the barrel underside to push the broken bit out?
Thanks in advance!
Thanks in advance!
