Hoping to improve 7” front brake and forks on 6T
691 views 25 replies 6 participants last post by  BMF
#1 · (Edited)
The front brake on my ’52 T-Bird has never been great but lately it’s become completely useless, it will barely slow the bike when I’m rolling it down the ramp off the bench and on the last ride, going down a gentle hill, I pulled the lever as hard as I could and the bike continued to speed up.
Happily the rear brake has always been really good.
So definitely time to take it apart and have a look.
The drum and linings looked ok, a little rust on the drum and linings a bit glazed, the grease had dried out on the pivots and cam so I thought I’d clean and lube appropriately and reassemble. On cleaning the shoes however, I found the lining material coming away one shoe.
I remember I had these shoes re-lined by a local brake place back in the early 90s when I rebuilt the bike, this was probably not long after the demise of the asbestos materials and before the new materials had been developed to have good friction.
So I’ve ordered a set of new shoes made in UK by LF Harris.
I’ve cleaned the drum up, I did lightly skim this back in the day so I might have to arc the new shoes to it..
I’ve also had the rest of it to bits and cleaned it all up and lubed the cam pivot and run some engine oil through the cable.
With the wheel out I noticed the forks are showing different amounts of stanchion! Not sure what’s going on here!
#3 ·
The flat side of my shoes are cupped from the action of the cam, probably one reason for poor braking.
Also I’ve noticed the images of replacement shoe online show a reinforced area which presumably bears on the pin opposite the cam and allows the shoes to float a bit?
Mine have a semi circular end which fits the pin (at least it does with the shims I made donkeys years ago..)
Or have I ordered the wrong type?
Forks to follow..
#9 ·
Hi John, I also had those shoes with the little bite out of them, I replaced them with a flat type and breaking is fine.
Thanks for the tip about those felt washers for the legs, never knew about them. Will also get a pair but not sure when everything will be apart again to put them back as things are going quite smoothly at the moment 😉, fair I said it. I've tempted fate I'm sure. They will soon be installed🤣
#14 ·
All parts arrived and the front end is going back together nicely.
Felt washers and new seals fitted, fork legs are now the same length! I bought new bottom bolts and copper washers as the old ones were an odd pair and pretty rusty/mangled.
Had a head scratch over which way round to fit the floating shoes but a phone call and a diagram online sorted that.
As the drum has been skimmed I should really be using thicker brake material but I’ve fitting the spacers I used with the old shoes which give a reasonable lever position, we will see how the brake works if it’s still underwhelming I’ll have the shoes up on my mate’s lathe and skim them to the correct radius.
#16 ·
Years ago now, but I had Ferodo reline shoes and with an upgraded material and it did make a significant difference over stock. I can't even remember which bike it was for. But might be worth looking into.
Just checked they're still in Chapel en le Frith
www.ferodo.com
I guess you could try them, but they are a brake material manufacturer, I doubt if they do relining. Back at post #2 I advised Villiers Services, they really do know what they are doing on re-lining!
#18 ·
#20 ·
She’s all back together, forks are working nicely but pushing the bike around I’m not convinced the front brake is much better than it was.
I need to ride it to see but I may be taking the shoes out again to arc them.
@BMF Did you use the original round pivot pin with the new floating shoes? I had to use some spacers to pack them out a bit.
Did your brake arm end up at a decent angle about 90 degrees?
#24 ·
Hi @newsh , apologies for the late reply, being a bit crazy over here.
Here is a picture of my brake lever, no I didn't need any spaces.
I bought these shoes from Monty, but I must be honest. I might take them out and send them to Villiers's to be relined with something softer as the front brake I still feel is not as good as the back one.
These shoes fitted perfectly even though they claim to be for a full width drum.
#22 ·
It’s a strange design of brake.
Were they trying to minimise leading shoe effect?
I read an old thread about this today in which the chap tried switching the shoes around to get more self servo effect on the leading shoe and less contact on the trailing (on your suggestion), no improvement apparently but no lock-up either. The rear brake works great but then the lever is about 5 times as long and has the weight of your leg on it!
