Flashing brake light for safety
310 views 16 replies 7 participants last post by  Bike2k2
I’ve always installed a brake light flashing device on my motorcycles in order to be better seen. Is there a unit that is recommended that plays nicely with the canbus system?
#5 ·
#9 ·
In Wisconsin, they are against the law, as flashing red is only allowed on emergency vehicles.
That said, I have flashing brake lights on both my bikes and they work great at keeping cars from getting too close and have never been pulled over by authorities. I use it quite often when I’m just sitting at a stop light and a car is approaching from behind and they always stop further behind than usual.
#10 · (Edited)
Bike2k2, I have installed this unit on my 2017 Bobber back in 2019 as recommended by another rider on the Triumphbobberforum.com
I bought it on Amazon, but don’t see the exact thing there. There are others listed by the same company that may work, but I’m in no chance a guru on these electrical things.
Here‘s the instructions I got from the forum member.
Good Luck!
#12 ·
Some of these continue to flash as long as the brake is on. These can be annoying to drivers behind you and they can tune it out. The vizi-tec flashes and then goes solid, i had one on my 2012 Bonneville T100 and it plugs right inline with the brake, no splicing. The one I use from Admore on my 2024 Tiger 900 GT flashes multiple times and then changes to a solid red light. It is separate from my brake light which works normally without flashing. It also has sequential turn signals which are nice, but it requires a bit of easy wiring.
#16 ·
Yeah, the one I had would flash quickly for several seconds the flashing would slow down and then the brake light would become solid. It definitely tripped some people out.
After that, I dumped the system and decided to go full reckless mode, bobber'd the bike and installed a Model A tail light. ...but hey, my little bullet LED rear turn signals still went on with the brake light. :p Doing a little border patrol duty here....
#13 ·
To add to the input above from ND TIGGRR, neither the Vizi-Tec SupaBrake nor the Denali B6 flash perpetually, which as someone pointed out, is illegal in some jurisdictions. They would be stupid to release such products, and I would be similar to buy them. The Vizi-Tec (especially) can be configured for multiple light display patterns but the default is to flash a few time and then go solid, with a recycle time of about 12 seconds (IIRC). No one would stop anyone for flash-then-solid behaviour as they would not surely win a court challenge.
