so its time to fit Twin Power starter idler boss ugrade to my 2004 Bonny this seems to go well but you do lose most of the engine oil , so I think yes will do Oil and filter change, I order oil ,new filter and cup wrench to remove old filter I have checked very carefully all sources say oil Filter HF191 68mm, so i come to remove old filter and its 65mm and i cannot get it off , tried putting a screwdriver thru it no good what is going on, now I will have to get a 65mm wrench to shift it and what do I fit HF191 (68mm) or HF204 (65mm) the smaller size is for 2005 on
