hey guys i am find that my Bonnie doesn't start straight away, i keep her on a charge overnight not sure if it's a common thing coming into winter? have to start her a few times before she kicks in... 2024 model
Probably means float charge. After the initial charge, a smart charger should step down to around a constant 13.2V which is nowhere near 1 amp. It helps to keep sulfate from forming..
A bike battery needs no more than 1 amp at 12v......a bit less than 1 amp would be kinder to the battery.
So tell me why are you charging it 24/7?????
Where this has been an issue, it's not the fuel itself. An increasing number of new motorcycles have adaptive ECUs and some form of knock sensor. These are needed because bikes have to run so lean to pass Euro V. My KTM, for example, with a 12.7:1 compression ratio actually needs premium and will adapt to run rich on regular. That enriched mixture is 'saved' at shutdown pending the next operating cycle, making cold starts easier.So high octane fuel prevents pre-ignition and subsequent "knocking" in high compression engines, avoiding premature detonation rather than combustion from the plug flame front.
Australian Head of Tech's argument may be that the high octane fuel is preventing the spark plug from igniting the fuel at the right time. At the same time the programming of the ECU is so poor that it does not know to richen the mixture sufficiently during a cold start.
I would have thought that if premium fuel were the cause of poor starts, then something else is wrong, such as a weak ignition system.
Apparently ethanol is an octane booster - and that would allow manufacture of lower quality fuel with less carbon content.
I'm with Nick on this one, though there is no harm in trying low octane fuel recommended by the manufacturer to see if it helps.
Changing the subject a bit, I always run premium diesel in my automobile because the extra detergent additives prevent carbon build-up in the exhaust system. Gasoline is not nearly so messy.
