Chain clicking noise
47K views 6 replies 6 participants last post by  MrTwistie
The chain is probably worn, like noted above but I am also guessing the nut on your front sprocket is loose as well. It happens and there are several threads about that.
I heard that exact clicking noise while pushing around my bike---forwards and backwards---in the garage. I noticed the loose nut when I went to change the sprockets and chain. The clicking noise went away after that. I must say that I'm not entirely certain the loose nut and the resulting play in the sprocket caused the clicking or whether the chain on worn sprockets caused the clicking, or both. Take a look at the nut first. Easy to do.
Then take a look at Hermy's. Triumph chain and sprocket kit for $200.
And note who makes the box (one of Forchetto's favorites! :) )
Please let us know what you find after you've investigated.
Cheers....
