Hey all!
I have a 2016 Street Twin that I recently had some work done at a dealership and a third party. Dealership worked on my transmission as I dropped it and bent something ion the detent arm assembly. The third party work on my tires, chain, and brakes.
Finally got it back after 2.5 months of waiting for repairs to be completed only to have found ANOTHER issue. Upon acceleration, my bike would randomly loose power. After some online research, i found that the brake switch is my issue and I confirmed this in my own findings. My brake light never dims, it only stays on at the brightest as if Im braking.
Thinking it's a simple adjustment to the rear brake and how it triggers the brake, I started my work. HOWEVER, when i removed the brake switch to test it, it still didnt stop the brake light from being activated.
As it turns out, when I press BOTH brake switches, the light will dim! If only one switch is pressed, the light will remain bright. This suggests to me that the polarity of the switch has been changed!
How do i change back the polarity because I cant figure it out. ECU restart didnt do anything and I cant find any information about a relay. Any help will be greatly appreciated!
