Hi All I am having an issue with my 1020 Bonneville SE. All was fine until I tried to use it earlier this week. When I turn the key the light come on as usual but it does not do its power up sequence and I have nothing on the clocks. needless to say operating the starter button does nothing.
I have checked and tested all the fuses, the kill switch and the ignition switch and all seem ok. When I jump the starter solenoid the bike turns over. I have checked all of the connections in the headlamp and looked for broken or chafed wires and everything appears OK. I also swapped the two identical relays (fuel pump and ecm I believe) and that made no difference. I have charged the battery and also tried a jump pack. All of the ancillary electrics - lights, indicators horn etc all work fine.
In the week or two prior to this happening the bike did stutter very slightly a couple of times but I thought noting of it.
Any suggestions where the problem might lie would be gratefully received.
Kevin
Kevin
