I'm working on a "Bonneville" that is never going to be a show bike as it's a collection of 1968 and 1969 bonnie parts on a TR6C frame. I want to get it serviceable from an engineering stand-point. I would have left it as-is and just done smaller bits of work but unfortunately there was a large oil leak from somewhere near the base gasket on the engine that may have been from the pushrod tubes (looked more like the base gasket though).
I've decided to try to fix up the bike along the lines of how an owner might have been able to back in the day. In other words I'm not stripping every item and vapor blasting or powder coating. Instead I'm aiming for an economical restoration to usable condition. The Classic Motorcycle Channel on Youtube has a great series on building a low-budget classic restoration which is roughly what I'm aiming at.
The main issue I'm finding is that as you disassembly everything you have to keep making choices about what to keep and what to replace. The frame had minor chips in the paint and very minor rust in those areas. I've sanded those spots, applied rust convertor and then painted over the chips with black stove enamel. My latest find is that the fork stanchions, while serviceable along the length that moves inside the fork leg, are quite pitted and rusted above that line (of course this is covered by the boot).
I fully intend to update some parts such as taper roller bearings in the steering, electronic ignition and maybe some other parts as I go along. As far as possible I'll be polishing existing chrome. Engine is likely to need a rebuild and at the moment I'm trying to decide how far into the engine and gearbox to go.
I'm not keen on having to cad plate all the bolts, but can't really afford to replace them all either. I'm not sure what to do with them at the moment. I assume if I wire brush them then they'll rust pretty fast. I do plan to replace the engine case bolts, as I don't like screwing old bolts into alloy in case I ruin it.
Any advice on the fork stanchions and refinishing of bolts would be appreciated!
